Results 1 to 10 of 12
Thread: Cannot change vin in 12633238 E38
    Junior Member Jedi_Jr's Avatar
    Jul 2010
    Default Cannot change vin in 12633238 E38
    What is the procedure to change a VIN in a 2011 12633238 E38? I have tried it in the scanning tool and it refuses (out of range) and I have done a full flash with a file with the correct VIN and still no change, correct calibration, but wrong VIN. Junkyard v6 4x4 PCM and it works fine with wrong VIN, I just want the correct VIN in there.
    The usual method is with the scantool.
    The VIN you're trying to write is out of range...? I contacted Tech Support.
    There is a new restriction that is active in some E38 controllers and possibly other models as well but so far we've only seen it in E38 controllers.
    It prevents you from changing the VIN to any other value.
    To bypass the restriction we've found this procedure to work:
    1. Connect up the ECM (i.e. vehicle) to FlashScan and FlashScan to the PC as you would normally.
    2. Start the V7.5 Tuning Tool software.
    3. Start reading the contents of the controller.
    4. Once the software has started reading the controller, click [Stop].
    5. Click [ok] to the "Data transfer was interrupted" message.
    6. Do NOT switch off the ignition.
    7. Wait for the countdown to complete and close the window.
    8. Open the Security window and click on the [Check Status] button.
    9. Wait for the check status to complete, then goto the VIN window and change the VIN - it should work.
    10. Now switch off the ignition and wait for the countdown to complete (I would prefer if you waited 30 seconds instead of 15).
    11. Switch on ignition and the VIN should now be the new VIN.
    Aug 2006
    I am doing a VIN change and am stuck at step #8. I don't see a "Security" window. I do have the "Check Status" box. I clicked the Check Status and waited for it to complete. It completes but I don't see a "VIN" window. I am using V2 and just updated 7.5 about 5 minutes ago.
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    Jul 2010
    Look for the Flash drop down menu on the top bar and then select PCM security. Vin/BCC will be a tab in the dialog box. You can also change the vin from within the scanner at this point too.
    Nov 2008
    Thank You it worked perfect for me after spending an hour with no success.
    Interested to know Paul, this info should be made into a sticky! I havent played with an E38, just the E67 and Ive never had an issue changing the VIN.
    Jul 2010
    It worked per Blacky's instructions. Thanks!!!!
    Aug 2006
    I am still having issues. I am going to start a new thread. I don't want to crud up the sticky.
    Jeff
    Oh there is an easier way, just have the 'clear DTC' box ticked in the VIN change window.
  1. VIN Change
    By chrleb2 in forum Cummins 5.9L
    Last Post: June 16th, 2011, 10:38 PM
  2. can i change my vin with EFI
    By MARC75 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 13th, 2009, 11:03 PM
  3. cant change VIN
    By Samdogmx in forum Vortec V6/V8 Specific
    Last Post: November 12th, 2007, 10:35 PM
  4. vin change
    By 69camaro5speed in forum Vortec V6/V8 Specific
    Last Post: January 24th, 2007, 12:08 AM
