Results 1 to 9 of 9
Thread: Autocal Feture Modifications/Removal
    Apr 2011
    Default Autocal Feture Modifications/Removal
    Just wondering if there is a way we can remove the program function, or be able to have the option of not putting a tune in the program location, only in the full location. We get about one call a day from customers who skim over the instructions and don't read that they must full flash, and not program flash. I would just like to avoid any issues for the customer and ourselves.
    Apr 2011
    bump...
    There is an option in the next update of EFILive that allows you to tag a file as only full-flash or only cal-flash.
    Using that option you can supply a single file that is used to "upgrade" the customer's ECM and have that file tagged as "full-flash only".
    And you can supply a bunch of other calibration files that are tagged "calibration flash-only".
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    How bout instead of $0281 it says turn the key on. Can't count how many times I get called asking what that means or it won't program right. It's on the first line in the instructions people. Lol
    Dan's Diesel Performance
    www.dansdieselperformance.com
    Quote Originally Posted by dansdieselp View Post
    Who the heck ever reads instructions? It's just one persons opinion on how to use something
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Every day I say the same thing "yes, did you look at the USB drive I sent that says tutorials on it? If so, tell me which part of the video I have if me holding the autocal I need I fix!?" Lolol
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Apr 2011
    Great news! Thank you.
    Mike
    Dec 2005
    Did I see AUTO-LOCK for LB7 controllers ?????????
    www.mscservices.net
    Nov 2009
    Quote Originally Posted by GMC-2002-Dmax View Post
    That you did :-)
    -Kory
  1. 6L80 TM removal?
    By SRT10KLLR in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: October 23rd, 2012, 06:50 PM
  2. Dpf removal
    By Compcowboy in forum General
    Last Post: December 21st, 2011, 03:31 AM
  3. Sensor removal?
    By 02greysixer in forum Duramax LB7
    Last Post: November 30th, 2011, 03:14 AM
  4. Cat removal
    By pjaneiro in forum General (Petrol, Gas, Ethanol)
    Last Post: August 16th, 2008, 08:58 AM
  5. After Header Modifications? And O2 Question
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2008, 09:47 AM
