Results 1 to 2 of 2
Thread: how do i make sure its not running too lean
    Jun 2012
    Default how do i make sure its not running too lean
    I have a brand spankin new 2013 GMC 2500 and its actually a work truck so i definatly dont wanna mess it up but this truck is a bust when it comes to power and economy . the problem is i can adjust soo many things with efi i dont know were to start let alone if i am doing more harm than good ... has anyone been sucsessful tuning this kind of aplication if so HELP!
    Jun 2007
    I tune them all the time with good results. If you are really worried about running lean you need to get a WB. I use a Innovate and have had great luck with those.
    The trucks are very rich usually not lean so you should be safe. Make small adjustments and check your logs. A good log can tell you alot.
  1. Running Lean, only after startup
    Last Post: May 5th, 2012, 12:26 PM
  2. Running lean after tune
    By SRT10KLLR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 16th, 2009, 07:06 AM
  3. NEED HELP running lean after tune!!!
    By clg82 in forum Gen III V8 Specific
    Last Post: February 25th, 2009, 07:30 AM
  4. Running Lean at Idle
    By mikeyayell in forum Gen III V8 Specific
    Last Post: December 28th, 2007, 07:55 AM
  5. Running Lean
    By 91LS1S10 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 20th, 2006, 11:40 AM
