Results 1 to 3 of 3
Thread: AFR control by MAF and VE table combined?
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Default AFR control by MAF and VE table combined?
    On a LS1B style pcm what do you log to determine how much of the calculation is coming from the MAF versus the VE table to control AFR? Also does the MAF really control totally after 4000 rpm's? Been wondering about this for a long time.
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
    You can perform an experiment by zeroing out the VE table...
    so if above 4000 rpm the PCM for some reason uses the VE table you will see a drastic change in logged cylinder airmass;
    I talked to some people who said they have seen this in a few situations (possibly the exceptions to the rule).
    Nov 2011
    I at one point set that value 400 and later disconnected the maf. The car would start and immediately shut off. Makes sense.
  1. What tables control AFR on a cold start?
    By tinindian in forum Gen III V8 Specific
    Last Post: April 18th, 2011, 11:51 AM
  2. LBZ/LMM combined operating system
    By KillaKustomKables in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 2nd, 2010, 10:06 AM
  3. PLX SM-AFR Serial control not found.
    By aaronr in forum FlashScan V2 BB Logging
    Last Post: February 15th, 2009, 07:59 PM
  4. Manual AFR control with Scan Tool
    By 2002_z28_six_speed in forum General
    Last Post: September 14th, 2007, 06:23 PM
