Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Need heelpp ASAP Truck wont start.
    Feb 2012
    Default Need heelpp ASAP Truck wont start.
    Ok so i am programing a 04.5 lly and while programing it froze half way through the flash. Now it will get all the way to where it is programing and it stops different places 7k 15k 20k 25k you get the drift. Any way then it says retrying last block. I have tried everything it seems unplug radio fuse info fuse pulled the whole radio out jumper cables on while flashing unpluged batteries for 5 min 15min 30min and 10 hrs no change have tried the alt key low speed high speed together not together no good. have read alot on this and it does not have after market alarm or remote starter. i have tried restarting my computer and flashing that way. not sure what else to do any help would be much appreciated have a guys truck sitting at my place and he needs it asap.
    __________________
    Just some guy
    Mar 2009
    Is your software up to date? There was an issue with lLY's doing this during a flash that was resolved awhile back.
    Feb 2012
    Yes thanks for the help all is up to date double checked it last night at like midnight. Hoping that was the problem.
    Just some guy
    Feb 2012
    This is what it is doing.
    14:54:02.388: Scanning for EFILive FlashScan V2 HAPI
    14:54:02.404: Autodetect interface ...
    14:54:02.684: Interface firmware version: 2.7.35
    14:54:02.684: Connection to [FSV2] interface is OK
    14:54:02.700: CAN-VPW Bridge Activated
    14:54:02.762: Current protocol set to: "SAE J1850 VPW"
    14:54:02.762: Autodetect PCM...
    14:54:02.809: Connection to PCM is OK
    14:54:02.825: Current protocol: "SAE J1850 VPW"
    14:54:03.043: USB driver version: 2.8.2
    14:54:03.043: USB library version: 3.2.0
    14:54:03.059: Interface firmware model: FSV2
    14:54:03.090: Interface firmware model: FSV2
    14:54:03.106: Interface firmware version: 2.7.35
    14:54:03.121: Interface firmware date: Jun 22, 2012
    14:54:03.152: FlashScan serial number: 00000000000
    14:54:03.168: FlashScan license number: 00000000000
    14:54:03.464: Getting status...
    14:54:04.042: Status: Calibration missing.
    14:55:27.736: Disconnecting ...
    14:55:28.188: CAN-VPW Bridge Deactivated
    14:55:28.188: Disconnected
    14:55:28.874: Scanning for EFILive FlashScan V2 HAPI
    14:55:28.890: Autodetect interface ...
    14:55:29.171: Interface firmware version: 2.7.35
    14:55:29.171: Connection to [FSV2] interface is OK
    14:55:29.202: Autodetect interface ...
    14:55:29.608: Interface firmware version: 2.7.35
    14:55:30.637: Interface firmware version: 2.7.35
    14:55:30.653: Connection to [FSV2] interface is OK
    14:55:30.653: Autodetect PCM...
    14:55:30.684: Connection to PCM is OK
    14:55:30.902: USB driver version: 2.8.2
    14:55:30.918: USB library version: 3.2.0
    14:55:30.934: Interface firmware model: FSV2
    14:55:30.949: Interface firmware model: FSV2
    14:55:30.965: Interface firmware version: 2.7.35
    14:55:30.996: Interface firmware date: Jun 22, 2012
    14:55:31.012: FlashScan serial number: 00000000000
    14:55:31.027: FlashScan license number: 0000000000
    14:55:31.058: Disconnecting ...
    14:55:31.480: CAN-VPW Bridge Deactivated
    14:55:31.480: Disconnected
    14:55:32.150: Scanning for EFILive FlashScan V2 HAPI
    14:55:32.166: Autodetect interface ...
    14:55:32.447: Interface firmware version: 2.7.35
    14:55:32.447: Connection to [FSV2] interface is OK
    14:55:32.462: CAN-VPW Bridge Activated
    14:55:32.540: Current protocol set to: "SAE J1850 VPW"
    14:55:32.540: Autodetect PCM...
    14:55:32.572: Connection to PCM is OK
    14:55:32.587: Current protocol: "SAE J1850 VPW"
    14:55:32.806: USB driver version: 2.8.2
    14:55:32.806: USB library version: 3.2.0
    14:55:32.837: Interface firmware model: FSV2
    14:55:32.852: Interface firmware model: FSV2
    14:55:32.868: Interface firmware version: 2.7.35
    14:55:32.899: Interface firmware date: Jun 22, 2012
    14:55:32.915: FlashScan serial number: 00000000000
    14:55:32.930: FlashScan license number: 00000000000
    14:55:33.242: Getting status...
    14:55:33.804: Status: Calibration missing.
    14:55:36.362: Bootloader version: DLLY_v1.4F (0810-59D1)
    14:55:36.362: Preparing ECM for reflash...
    14:55:36.394: ECM reports "Not secured!"
    14:55:36.394: Initializing ECM...
    14:55:37.205: Initializing ECM, step 1 of 4
    14:55:37.205: Initializing ECM, step 2 of 4
    14:55:38.016: Initializing ECM, step 3 of 4
    14:55:38.016: Initializing ECM, step 4 of 4
    14:55:38.468: Initializing bootloader...
    14:55:38.796: Initializing bootloader, step 1 of 5
    14:55:40.824: Initializing bootloader, step 2 of 5
    14:55:41.542: Initializing bootloader, step 3 of 5
    14:55:42.244: Initializing bootloader, step 4 of 5
    14:55:42.930: Initializing bootloader, step 5 of 5
    14:55:43.445: ECM ready for reflashing.
    14:55:43.663: Request serial number...
    14:55:43.757: Serial number: M0411402LFV1
    14:55:45.114: AMD AM29BL802C - 1MB
    14:55:45.457: Erasing ECM flash memory... (please wait up to 120 seconds)
    14:55:45.473: Waiting 1 of a possible 120...
    14:55:46.487: Waiting 2 of a possible 120...
    14:55:47.501: Waiting 3 of a possible 120...
    14:55:48.515: Waiting 4 of a possible 120...
    14:55:49.529: Waiting 5 of a possible 120...
    14:55:50.543: Waiting 6 of a possible 120...
    14:55:51.557: Waiting 7 of a possible 120...
    14:55:52.571: Waiting 8 of a possible 120...
    14:55:53.585: Waiting 9 of a possible 120...
    14:55:54.599: Waiting 10 of a possible 120...
    14:55:55.613: Waiting 11 of a possible 120...
    14:55:56.658: Waiting 12 of a possible 120...
    14:55:57.688: Waiting 13 of a possible 120...
    14:55:58.733: Waiting 14 of a possible 120...
    14:55:59.747: Waiting 15 of a possible 120...
    14:56:00.761: Waiting 16 of a possible 120...
    14:56:01.775: Waiting 17 of a possible 120...
    14:56:02.414: ECM flash memory erased OK
    14:56:02.680: Reflashing ECM's memory...
    14:56:11.369: Retrying previous block...
    14:56:19.106: Retrying previous block...
    14:56:27.905: Retrying previous block...
    14:56:38.170: Retrying previous block...
    14:56:47.405: Retrying previous block...
    14:56:57.982: Retrying previous block...
    14:57:07.435: Retrying previous block...
    14:57:09.494: Stopping, please wait...
    14:57:17.544: Retrying previous block...
    14:57:17.560: Total time: 01:14
    14:57:17.560: Data compression achieved: 32.4%
    14:57:17.591: ECM is in an unknown state.
    14:57:19.728: Clear emisison related DTCs...
    14:57:20.789: Autodetect interface ...
    14:57:21.054: Interface firmware version: 2.7.35
    14:57:21.054: Connection to [FSV2] interface is OK
    14:57:21.054: Autodetect PCM...
    14:57:22.442: PCM not detected.
    14:57:23.254: Disconnecting ...
    14:57:24.190: CAN-VPW Bridge Deactivated
    14:57:24.190: Disconnected
    14:57:24.205: Data transfer was interrupted.
    14:57:28.370: Done!
    Just some guy
    Feb 2012
    made it to like 5k loaded on that one.
    Just some guy
    Looks like you are all up to date.
    Maybe try reflashing through the V8 software instead. But to me it looks like something on the communications bus is interrupting the process, maybe try pulling the BCM fuse out as well. Things that are known problems are devices like iPod adaptors or XM radio adaptors that are wired on to the communications bus. Unfortunately they might not be disconnected when you unplug the radio fuse.
    Feb 2012
    ok will try now thanks
    Just some guy
    Feb 2012
    i dont know where the bcm fuse is nots seeing it. also can i use my 7.5 files in v8 i dont ever use v8 so not sure
    Just some guy
    I don't know where the BCM fuse is either sorry.
    You can use your V7.5 files in V8 no problem.
    So a very quick run down on flashing with V8.
    Open the program.
    Click on 'Tune' (or press F3)
    Then when a new window pops up, choose 'Open' down the bottom.
    Find the file you are trying to flash in and open it.
    Then click on 'Full Flash' as it appears that is what you are trying to do.
    Then click the "Full Flash' button again and see how it goes.
    Lifetime Member Gregs's Avatar
    Sep 2008
    Quote Originally Posted by dieselguy9311 View Post
    I believe its under the hood
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
  1. HHHEELLPPP Truck wont start
    By MonsterMax in forum Duramax LLY
    Last Post: November 12th, 2011, 01:26 PM
  2. Need help fast truck wont start
    By way2much_01 in forum Petrol / Gas
    Last Post: August 5th, 2011, 09:46 AM
  3. help truck wont start!
    By chev in forum General (Diesel)
    Last Post: March 29th, 2010, 01:39 PM
  4. 'Race truck' wont start..
    By nonnieselman in forum Gen III V8 Specific
    Last Post: January 12th, 2010, 07:33 AM
  5. Help Truck Wont Start - Flash messed up somehow?
    By BlownAlaskan in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 11:17 AM
