Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Need heelpp ASAP Truck wont start.
  1. #11
    Feb 2012
    ok i tried the v8 software and it does not even make it to the loading part says invalid serial number then end the run.
    Just some guy
  2. #12
    Mmm ok, I think you are going to have to just start pulling fuses in the hope it kills whatever it is interrupting the bus. Previous poster gave a hint as to where the BCM fuse is.
  3. #13
    Feb 2012
    ok if you could tell me which fuses not to pull i will pull all of the other ones. lol crazy stuff.
    Just some guy
  4. #14
    I am sure when people have issues like this on the LLY it's always the Radio and BCM fuse that solves it. As for what not to pull, I don't know.
  5. #15
    Mar 2009
    There can be up to four fuses for the body control module. One is in the underhood panel and there will be one, two or sometimes three more in the interior fuse panel. Pull anything labled "TBC". "TBC" is Truck Body Computer. Hope that helps.
  6. #16
    Feb 2012
    Yes anything helps thanks alot.
    Just some guy
  7. #17
    Feb 2012
    Pulled all of the tbc fuses and a ton more fuse box is pretty empty made it the farthest it has but still only 41k out of 928k so really really far away.
    Just some guy
  8. #18
    Mar 2009
    Where are you located? Maybe you can find somebody with a bench narness to flash teh ECm that way so you can rule out the data bus.
  9. #19
    Feb 2012
    shelbyville ky 40065
    Just some guy
  10. #20
    Feb 2012
    i have found out that you can pull every single fuse out of the in truck fuse box and still communicate with the truck. its still is trying to load but stops at random spots and says retrying previous block
    Just some guy
  1. HHHEELLPPP Truck wont start
    By MonsterMax in forum Duramax LLY
    Last Post: November 12th, 2011, 02:26 PM
  2. Need help fast truck wont start
    By way2much_01 in forum Petrol / Gas
    Last Post: August 5th, 2011, 10:46 AM
  3. help truck wont start!
    By chev in forum General (Diesel)
    Last Post: March 29th, 2010, 02:39 PM
  4. 'Race truck' wont start..
    By nonnieselman in forum Gen III V8 Specific
    Last Post: January 12th, 2010, 08:33 AM
  5. Help Truck Wont Start - Flash messed up somehow?
    By BlownAlaskan in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 12:17 PM
