hi guys what settings should I be looking at to keep afm working in say ad mode
that's sd mode by the way
Are you wanting to turn AFM off or are you trying to keep it active longer?
well all I had done was turn the LTFT off and I had no more 4cyl mode. if it was my car I would not want the silly afm. and have also heard that something needs to be done to keep it active when in SD as well. I just don't have time to bugger around to work it out have other jobs to do. so any help would be great.
thanks turbo.
well I found the problem and fixed it up so all good
