Same OS number in that last log? Or different OS?
I think its time to try another OS, seems like you've done the research.
Its the same OS. I've tuned a few with the same OS and never had this issue. I may send him to the dealer for a full reflash. Worst come to worst I'll try a new OS and or new PCM.
Thanks for all the input!! It is appreciated. If anyone has run into this as well let me know. I will keep everyone updated with what I find.
Interesting, have you tried full flashing it for kicks? I dont know what other year OSs interchange, could you try an 05 OS?
I have tried a full flash, with the stock OS and a download from tune file depot. I'll check with a friend that works for GM and see if there is an upgrade to the OS. If there isn't ill try another PCM or even a previous year PCM.
So I thought I would update this thread. I finally got this fixed and working.
Here is a few things we did that did not work. We tried reflashing with same OS. We had the dealer flash from a tech 2 and it ended up being the same OS, still did not work.
I then used a 2005 OS and bingo, power enrichment but now I had a TAC module issue. I called a friend that had a 2005 TAC module and we swapped it for the 2006. Now everything is working great and the truck runs awsome.
Short version we used a 2005 OS and a 2005 TAC module.
Have anoher 7811 at my shop and no PE.
Does anyone know if there is a min torque enable/reqest setting or anything that has to be met like the TPS and MAP? I wonder is there is something else in this OS that has to be changed to be able and activte PE.
