Need help with e36
HI everyone
need your help to tune Commodore 2012 A6 stock only cat back
is that normal from e36 the timing at wot read only 13~15
log file and tuning file
Post tune .
Ok got it thx. Yep missed it in the original post . You are running IAT's up towards 60C and hi ECT of 100C+, so that will reduce the timing. IAT could be pulling 5 deg. ECT another 1.5 to 2 deg. There you have 7 deg alone (worst case). Add in 3 - 4 deg of KR at times. Worth checking what your octane scaler is. With KR that could be pulling timing back to your low octane table. Or copy hi to lo to take the lo table out of the equation for tuning purposes. Could also be some burst knock being thrown in at times. You could optionally zero that for tuning purposes and turn on again after tuning.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
