Results 1 to 10 of 14
Thread: Can't use EFILive Scan And Tune V8 (Windows Locale)
    Nov 2009
    Default Can't use EFILive Scan And Tune V8 (Windows Locale)
    Hi guys i have a problem that every time i tray to open EFILive Scan And Tune v8, it's not working and i can't use it
    i have windows 7 and i did all the updates and i use the latest version of efilive
    any suggestion
    You need admin privileges during install and usage (it can open the right image file, you did not install correctly).
    Nov 2009
    i have brand new window 7 with all updates, efilive is the first softwaer
    i use admin but still i have the same problem :/
    i did full format for the system but still the same problem
    Member Motorzane's Avatar
    Jun 2011
    Default can't use EFILive Scan And Tune V8
    Try right click on the icon and choose run as Admin
    Nov 2009
    i already did this
    Jun 2011
    What about a full uninstall and then try and reinstall the software again.
    Nov 2009
    i already did it, i even did full format for windows 7 and tried to install the software but the same result
    Have you tried changing the locale to US or Australia/New Zealand?
    Nov 2009
    u r the best since a year i couldn't use it, now for the first time it's work
    i can't believe it's work, a lot of thanks for everyone tried to help
    No problem, Ive seen Windows do weird things like this. Glad you're up and running!
  1. Replies: 5
    Last Post: August 17th, 2010, 04:11 AM
  2. Is this a Bug with EFILive Scan & Tune?
    By Biodiesel66 in forum FlashScan V2 BB Logging
    Last Post: January 29th, 2010, 06:25 AM
  3. EFILive Scan/Tune tool isues
    By Cougar281 in forum General
    Last Post: February 5th, 2008, 01:37 PM
  4. Problems with upgrading V2 from scan only to scan and tune...
    By DngrZne in forum General (Petrol, Gas, Ethanol)
    Last Post: November 26th, 2006, 03:41 AM
