Results 1 to 6 of 6
Thread: Scaling MAF for Supercharged GM LS1
    Aug 2012
    Default Scaling MAF for Supercharged GM LS1
    Has anyone tried to scale the MAF to be used in a supercharged application on a LS1 (with 12psi boost it does peg it early)? I would really like to increase the limit of 512g/sec but I think it is a software limit? Enabling the MAF instead of going speed Density provides better driveability and response over varying atmospheric conditions.
    The LS1B MAF limit of 512 g/s is in the PCM.
    You would have to scale the IFR/MAF/VE down by the same factor, and you would have to shift any tables that reference airmass or airflow.
    Aug 2012
    Can EFILive change the MAF hard limit of 512g/s in the PCM? This would really be great because for those cars that have a blower, we would not have to try to scale everything or go to speed density.
    No, it's a limitation of the PCM hardware.
    correction: it's a limitation in the OS/code section as Greg says in the next post below.
    Apr 2009
    You can't change the 512g/s limit, as this is in the code section, not the calibration data. However, it is possible to scale your calibration data down to stay under the code's limitations and still have a perfectly functioning control system. The loss of resolution is not significant in most cases. The procedure for scaling injectors/MAF has been discussed on here before and is covered in detail in my professional training materials.
    ~Greg
    Calibrated Success - EFI Training and Tuning Done Right
    GM Beginner's Guide DVD available now through Summit!
    Engine Management: Advanced Tuning - Amazon's best deal for the EFI crowd.
    Aug 2012
    Greg,
    How will I know if the MAF is accurate to around the 70lb/min mass airflow value that I will need for the blower? Is the loss in resolution stemming from the scaling percentage employed to the MAF? If this is effective, why would most tuners still want to go to speed density?
  1. 2012 CTSV Maf scaling, open loop issues.
    By ditosmotors in forum E37, E38 & E67 PFI ECM's
    Last Post: June 27th, 2012, 01:37 PM
  2. Why reduce MAF scaling values on a basically stock E38?
    Last Post: June 24th, 2011, 10:44 AM
  3. Advice:427 supercharged LS9 injector/LS7 MAF
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: May 2nd, 2010, 02:25 PM
  4. Replies: 10
    Last Post: August 27th, 2009, 09:38 AM
  5. I need a stock MAF for a 2000 LS1 camaro!
    Last Post: October 25th, 2005, 02:20 PM
