In better understanding how the airmass is finalized to determine fuel mass the following logic is used;
The MASS AIR meter measures the grams/sec of air mass entering the intake manifold. This is a raw measurement. What the PCM really cares about is grams/cylinder NOT air mass. However in order to determine the exact grams/cylinder it needs to be "predicted" based upon certain assumptions.
This is where the VE coefficients come into play as well as intake manifold volume.
At steady state the MASS of air entering the MAF should "closely" compare to the grams/cyl entering the combustion chamber.
The diagram above shows the air dynamics associated with a throttle movement. When the throttle (in blue) moves, there is a big rush of air through the throttle to fill the intake manifold. The air flowing into the manifold (as measured by the MAF sensor) is in red. The air flowing into the cylinders (in green) lags behind this because of the manifold filling effect. The area between the red and green curves is the amount of air that has added to the manifold.
At the beginning and end of the chart, the system is in steady state, which means that the amount of air in the manifold is constant. The air flowing through the MAF sensor is equal to the air flowing into the cylinders. Once you jab the throttle that all changes and the surge of airflow (transient condition) now requires that the speed density calculation assist in the prediction of grams/cylinder. Stuck in the middle of the this condition is the intake manifold that has a known volume as indicated in the {B8036} parameter for volume....
Now.....we install a LSX 102mm intake or better yet a positive displacement supercharger.....seeing how the 15 string polynomial calculations looks at this it seems like we really should be correcting for this when making these changes.
Question I'm trying to answer is the value that is noted in a give calibration is the raw manifold? or with the runner in the cylinder head....or.....with the neck of the throttle body.....etc.....
This also leads into the "Predicted Charge Temp Coolant Modifier" {B0179} and "Predicted Charge Temp Filter" {B0180} as these are also tables that derived as a dynamic of the intake manifolds design.....
It is necessary to know the mass of air trapped in the cylinder when the inlet valve closes. The amount of air trapped in the cylinder is used to calculate the amount of fuel to inject, spark timing, and the torque estimation. oh!!! Torque estimation......hmm....doesn't the 6L80/90E require torque values for shifting.........I'm exhausted for explaining that to people who keep destroying those trannys.......
It is known that a speed density calculation of fresh air mass matches the actual trapped fresh air mass when the speed density calculation is timed to occur at Bottom Dead Center (BDC) of the intake stroke. Because of the way the engine control module works, the calculation must occur at approximately Top Dead Center (TDC) of the intake stroke. This is to allow a fuel mass calculation based on the fresh air mass estimation to occur in time for the fuel to be injected before the intake valve closes.
There is a lot more to this topic but right now I'm homing in a the importance of this value.......
Howard
