Results 1 to 9 of 9
Thread: I can't full flash with W8
    Jul 2003
    Default I can't full flash with W8
    any workarounds? besides going back to w7 or xp.
    I flashed with W8 no problem using V8, when opening the V7.5 Tune Tool I only get half of the status bar (loading calibrations bar). I didnt try flashing with V7.5 and Ive only flashed a T43 a few times with W8 and V8.
    Have you tried running the Scan and Tune tools in compatibility mode for W7?
    What are you flashing from (V7, V8, V2)...?
    Jul 2003
    Both v7 and v8 cable is v2
    Yes I have tried all the possible combinations of compatibility modes etc even doing the install itself in compatibility
    I have no issues with cal flash though
    The program tries to flash and after sending bootloader ot automatically says completed
    With serial wideband...?
    Jul 2003
    Serial wodeband?
    Is your wideband connected to your V2 using serial comms or analog voltage...?
    Jul 2003
    Yes and No... both ways.. connected or disconnected... it will jump to the just finished without going through the prep steps.
    I'm sure that is the old 'non admin' problem, try running EFILive with admin rights (not sure how you do that on Windows 8), but Win 7 was just right click on the icon and choose Run as Admin.
  1. Why cant I full flash?
    By 01Blackerado in forum Gen III V8 Specific
    Last Post: March 17th, 2011, 10:11 PM
  2. Pre Full Flash to Full Flash Tune Question
    By Donovan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2010, 12:43 PM
  3. Full Flash
    By L31Sleeper in forum Vortec V6/V8 Specific
    Last Post: November 26th, 2009, 10:25 PM
  4. HELP cant full flash
    By Madspeed in forum Duramax LLY
    Last Post: April 23rd, 2007, 07:05 PM
  5. Full flash
    Last Post: June 11th, 2006, 06:28 PM
