The rear O2S are the same as the front O2S (other than the plug maybe)...
you can run them in the front O2S location (front harness sockets, and ahead of the cats if present).
Beware: on Corvettes it may be possible to inadvertently swap left/right O2S connections.
Yes, accord to GM training material and the Bosch Automotive Handbook, the O2S obtain reference air thru the attached pigtail, so you can't solder/splice wiring nor use alternate wiring.
