Results 1 to 3 of 3
Thread: Turbo Position Conversion table question
    Dec 2010
    Default Turbo Position Conversion table question
    Any reason why the engineers have this table? Why not make this graph linear instead of a curve? Or why not actually make this like the Duramax values?
    I have a theory it corresponds to the actual percent open since the vanes % area isn't based on a linear curve.... Any thoughts would be helpful!!!
    Dec 2010
    Any thoughts? I would greatly appreciate it!
    Junior Member KDubya's Avatar
    Jun 2011
    At 50% commanded the vanes are at 85% the way it is stock. If you make it linear, at 50% commanded the vanes are at 65%. So, to me, if you make that table linear you will be decreasing how fast the boost comes in. Not sure why the engineers did it this way but I would imagine it's for better smoke control or less soot production on a stock truck. Just my $.02.
  1. Table F0505 Pedal Position Question
    By LBZoom in forum Cummins 5.9L
    Last Post: June 6th, 2011, 03:34 PM
  2. turbo 400 conversion
    By MENIOS in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2010, 11:26 AM
  3. Turbo Vane Target Position Question
    By dieselz28 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 21st, 2010, 12:38 AM
  4. LMM-Turbo Vane Target Position
    Last Post: January 23rd, 2010, 06:31 AM
  5. Min. turbo vane position?
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 9th, 2007, 10:56 PM
