Results 1 to 8 of 8
Thread: Custom O.S V5 gets a run
    Default Custom O.S V5 gets a run
    So how else does someone tune an LS1 like this one?
    We will do a write up on this monster soon, 270+ cam, nearly 620 N/A Hp at the wheels, 8300 RPM!!
    This has been an awesome beta test for the Alpha-N custom O.S for sure (that still supports 3bar boost).
    Marty at HPF in Melbourne, for tuning this thing
    I have been testing the 05 OS now for 6 months on my car both as a tps/blown combo and a tps/na combo with switching based on map settins for a blended map , for a engine like Higgin's combo it will really work well.
    That is true Delco, you have been running it for sometime now, only, I think you probably had 'some' manifold vacuum to work with at idle?. People might be interested in hearing how hard it is to setup a TPS based VE from scratch, not 'how to' but how difficult it can be.
    Yes I have used it in house on a couple of very big 270 deg cams with great success , with the stuff you added in it can be a breeze to get it running ok within a few hours.
    Something as wild as Nathans rig is going to take a little longer to get 100% right but it can be done thanks to Ross and the guys at EFILIVE
    I cheated I had vacuum and Boost to work with , when we first started to test it I used it on the Monaro , mapping all the tps points and then switching so that above a set pressure and rpm window it reverted back to MAP , made for some crisp throttle response.
    looking forward to the read and some more pics of the setup
    Quote Originally Posted by Delco
    Oh, I didn't realise you had done some like that. Did they also have that trumpet style manifold or the FAST?.
    FAst , custom tunnel ram and a 8 TB manifold as well as a couple of cammed blown combo's have all been tested on.
    I even did a no thottle body setup just TPS sensor ( dont ask ) as a dyno test , went quite well but not a chance of being driven.
    Alpha-n is great for a track car , if fuel consumption is a issue then I would say its not as precise as map.
    Presently I am switching between alpha-n and 2 bar map while playing on a regular basis
    Jan 2005
    i'm all ears
    Oct 2005
    You guys are having all the fun...
    I take it that it is almost ready for release then?
    2014 VF SV LS3 Maloo.
  1. Two PCM's with same Custom OS HELP
    By superspeed in forum Gen III V8 Specific
    Last Post: February 1st, 2009, 02:45 PM
  2. custom OS with efi v1
    By dsmlights in forum Custom Operating Systems
    Last Post: December 5th, 2007, 07:28 PM
  3. Why LM-1 Custom PID???????
    By 2002_z28_six_speed in forum General
    Last Post: June 4th, 2007, 12:52 AM
  4. Custom Os???
    By FFP in forum Custom Operating Systems
    Last Post: December 7th, 2006, 01:11 PM
