Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: hard to start after reflash
    Jan 2012
    Default hard to start after reflash
    I swapped my 4L60E to a 4L80E in my 01 GMC Sierra. I am using COS 0202003. When I do a reflash its hard to get the truck started. It will crank and go to 1000 rpm, then die. It will do this 15-20 times. then when I start it the rpms will go to 2000 for about 5 sec then settle down to the desired idle rpm. can someone look at my tune and help me out. Thanks.4L80.tun
    2011 Cadillac Escalade ESV. BTR 218/224 .553/.553 110LSA. Built 6L80 with 278mm Circle D 2800 stall converter.
    Im looking at it now, just a heads up I get a warning that A0009 Boost VE is out of range. But I dont see any values above 500 so Im confused here...
    To clarify, this problem did not exist when you were running the exact same tune just with a 60E trans segment?
    Once it actually starts, then the RPMs settle to desired (either 750 or 775 per your tune) and it continues to idle just fine until you flash it again?
    The idle section isnt stock, have you done a true hot/cold idle calibration?
    Erik, if you view it in g*K/kPa you will see it.
    Try setting P0101,2,3 in C6001 to A:1-Trip.
    Jan 2012
    It's didn't happen before. It's a heads cam full bolt on procharged build so pretty much everything has been changed. Joecar, I'll give that a try
    Jan 2012
    Once it starts its fine after that. Until I reflash it with a new tune
    Jan 2013
    Thank you so much !!! happy new year 2013 : -)
    Quote Originally Posted by ht124534 View Post
    What car do you have...?
    Jan 2012
    Im still having issues with it not wanting to start after a reflash. Is there anything else I can try?
    Can you post a log file of it not starting.
  1. hard re-start
    By amiller406 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 29th, 2012, 01:39 AM
  2. truck won't start reflash failed
    By camiauto in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 18th, 2012, 10:44 AM
  3. Hard start condition with 5.7 in 2000 S-10
    By lowriders10 in forum Vortec V6/V8 Specific
    Last Post: May 30th, 2010, 03:56 PM
  4. Hard to start when hot
    By W_D_R in forum General (Petrol, Gas, Ethanol)
    Last Post: March 30th, 2010, 01:26 PM
  5. what is a hard start?
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 23rd, 2007, 04:02 AM
