Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: re-calibrating the fuel level sensor {F0101}
  1. #11
    Lifetime Member LB72004's Avatar
    Dec 2011
    yep, your right. just checked an LLY tune and sure enough it is "forward"
    so the above logged figures only applies to 26 gallon LB7 (maybe gas rigs too) trucks
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
  2. #12
    Dec 2011
    just logged voltage per gallon on the 34 gallon tank in my LMM.
    now, trying to input the values in the tune and having major issues. whoever decided on the values to use for volts in the tune at GM should be shot. why would the values drop from 5.0 volts to 2.502 volts then more reasonably from there. there is a whole lot of range between those values that is needed for accurately rescaling the gauge. well i am going to try putting some of the logged values into the tune and see what it does. just wish it was more like the LB7. that one has more values than needed.
    anyone, Hint, Hint: Ross, Paul, Cindy, know if those voltage values in {F0101} can be changed to something more usable?
  3. #13
    Dec 2012
    Quote Originally Posted by LB72004 View Post
    I wondered about that jump in the F0101 table when I was looking at it, myself. I haven't done anything with mine since I tried to update firmware last week and bricked my FlashScan... hopefully someone gets back and gives some answers on this.
    2008 GMC Sierra 2500HD CCSB
  4. #14
    Dec 2011
    Well, not being able to get my gauge working properly and running out of fuel before the light came on i decided to replace the sender.
    this is what i used: http://www.ebay.com/itm/Auto-Meter-3...a057df&vxp=mtr
    it has the needed 30-240 ohm range. i set it up in the tank last night so that it at empty it is at 1.9 volts and at full it is 0.7 volts. this allows my to avoid the stupid GM calibration section in F0101 and get a smooth drop all the way to E. i know i will have less figures to work with but i dont think that will be a problem. now i just need to run the tank dry and do the one gallon at a time fill/logging
    i dont think my logged data will be of any value to any of you unless you also install the Auto Meter 3262 and set it up like mine
    anyways, i will let you know how it works out
  5. #15
    Aug 2016
    Did anyone ever chart their voltages on the large tank LMM? I need to know what to expect for a 2008 Silverado Duramax CCLB. I am only getting down to 1.137 Volts at a full tank. Before I get in there and bend the float arm I would like to know what other people are getting
    It would be nice if the float dropped lower to get rid of the reporting empty with 10+ gallons left. The float needs to drop closer to the bottom in my opinion which would also push the sensor higher and get to a lower voltage on the full end. These things seem to be all over the place from reading posts on the net. The universal theme is that they all report empty way too soon. Knowing the voltages on a good working truck that is to OEM specs would be helpful. I am not sure if I need a mechanical fix or just a tune adjustment. The voltages won't change regardless of the tune, so that is better than a percentage calculated.
    I know the full can be fixed easily, but that won't do anything for when the float gets to the bottom and cannot drop any further. It is still about 3/4" from the bottom when the tank is dry. I did not measure it when I should have putting the sump in, but the float was right there so I could see it. I don't know if this is where it normally stops.
    Mine is only going to 88% at full when topped all the way to the fuel cap. I am waiting for the tuner to set it for the large tank instead of the small tank. He says this will fix it, but that would mean the full voltage on the small tank vs the big tank is different. Not sure... I am not sure if the full voltage changes between the two tank sizes. Unfortunately I am using locked tunes and cannot change anything even though I have everything to do it :(
  6. #16
    Junior Member ksieckmann's Avatar
    Apr 2013
    Boo hoo
    FarmTuned Performance Diesel
    www.farmtuned.com
    06 Cummins 03 6.7cr
  7. #17
    Aug 2016
    Quote Originally Posted by ksieckmann View Post
    Boo hoo
    Haha. I guess we will know more tommorow night.. got your email. I will let you know what it does after that and pester you some more
    Unfortunately I still suspect a sending unit change or adjusting the float in my future.
  8. #18
    Dec 2011
    i have the stock charted values (unbent float arm) somewhere, i'll see if i can find them for you.
    it is highly likely that my sensor was not working right. if i recall correctly, i was only able to see about 1/2~3/4 of the voltage range available. also, my float did go all the way to the top of the tank, or close to it, and all the way down to the bottom. i thought about bending the arm too, but if i am not mistaken, it would have prevented the float from reaching the top of the tank or reading full for a very long time. the only way i saw making it work was to extend the arm longer, thus changing it out for an aftermarket sensor
  9. #19
    Aug 2016
    Yeah. I may be in for a new sending unit. But I am going to load the tune with the proper size tank and the go from there. I have not looked at the shape of the arm vs. tank to see what bend might work. If you can bend the float down in a way that the float can still go all the way to the top without the wire hitting the top of the tank first, then it will be at a higher position at the sending unit and therefore at the desired lower voltage and drop lower on the tank to help with the low fuel report when there is lots of fuel left. The voltage at the empty side will not change as long as the float does not actually bottom out on the tank. There is plenty of room to go down without that happening. They set these things pretty high off the bottom if my truck is a typical setup.
  1. No Fuel Level After Flash
    By ls1mike in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: November 14th, 2011, 01:09 PM
  2. Replies: 1
    Last Post: September 22nd, 2010, 03:40 AM
  3. E38 fuel level sensor calibration
    By harascho in forum E37, E38 & E67 PFI ECM's
    Last Post: November 29th, 2009, 03:39 PM
  4. calibrating coolant sensor
    By steve40 in forum Gen III V8 Specific
    Last Post: June 2nd, 2009, 02:23 PM
  5. Fuel Level Sensor Primary F0101
    By Schweinmesser in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 10th, 2009, 05:01 AM
