Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
Thread: Vortec Calc VET Auto Tune, Final Answer!
  1. #51
    I tried it and I was able to select all the calc pids ok (no red X thru any of them).
  2. #52
    Dec 2010
    Done and uploaded new calc-pid text file.
  3. #53
    Dec 2010
    Me too! And got correct looking data in MAPS... Gone a little blind here with the issues and learning so I'm hoping somone can give it a shot with fresh eyes on a rig.
    If you have any luck with some new paremeters I think I found some:
    Commanded AFR x 2560
    Dynamic cylinder airmass
    Dynamic airflow, val = g/sec x 81.92
    SD grams/cyl airmass x 8192
    MAF derived cylinder airmass x 8192
    Mass airflow rate, g/sec = val/81.92
    #1, P0101: MAF sensor
    #2, P0102: MAF sensor
    O2 Switch Point
    Rear O2 sensor mv limits, to stop feedback
    Closed Loop Enable temp
    or
    Min/Max INT and BLM either way WB tuning would work without disconnecting O2 sensors.
    So the good stuff is there!
  4. #54
    Dec 2010
    I don't think EFILive have the time to revisit the Vortec (what you see is all they found back when)... do you want me to ask...?
    ( hmmm, this means it becomes difficult to do AutoVE )
    Any word back on adding whats needed? Or fixing SAE.AFR? Just seems wrong to use one marked SAE.AFR_B LS2...
    Missing and can't find :B0120: Change RPM Threshold for Airflow Calculation from 4000 to 400
    Eliminates any Airflow Correction from the VE Table
    B1147 MPH description says engine speed.
    Lots of stuff is there, way more then this list.
    ;Commanded AFR x 2560
    ;Dynamic cylinder airmass
    ;Dynamic airflow, val = g/sec x 81.92
    ;SD grams/cyl airmass x 8192
    ;MAF derived cylinder airmass x 8192
    :Mass airflow rate, g/sec = val/81.92
    ;#1, P0101: MAF sensor
    ;#2, P0102: MAF sensor
    ;Short term fuel trim min and max
    ;Long term fuel trim min and max
    ;O2 Swing points
    ;Loads of O2 sensor paremeters.
    That list is not all inclusive and some may not be needed to completly use all the tuning tutorials..
  5. #55
    Feb 2009
    I know this was a while ago, but I'm gonna see if this works for my L29 over the holidays. Seems like it's been forever since I played with the truck, mostly just been working it hard. Towing a big 5th wheel around and I need all I can get out of it (safely of course).
    So it'll be a bit, but I'll let you know how things work out.
    New to EFILive, been wrenching for about 20 yrs now. Current project: 1998 Chevy K3500, L29
  6. #56
    Apr 2009
    Quote Originally Posted by skills4lou View Post
    Will be interested to hear how this works. Its hard for me to tell if the calc pids was finalized in the thread?
    Josh
    1996 WS6|M6|CC305H|MMS Stage II Heads|Crane Gold 1.6 RR's|42 Lb Injectors|ATI P600B@12Lb's|3 Core ATI|BBK 58mm TB|SLP Shorties|Borla Catback||MWC&P FAB 9 w/3.70's|SFC's|LS1 Brakes|MSD 6AL|
    WIFEY: 2005 SBM TAHOE 4.8L. MAGNAFLO, HID'S,
  7. #57
    Make sure you understand the principles of the procedure...
    you may need to improvise if a pid or two are not supported.
  1. Auto VE or Calc VET or Auto Maf?!?!
    By Nver2loud in forum Gen III V8 Specific
    Last Post: October 23rd, 2012, 04:08 AM
  2. Cannot get the PID's for either Calc or Auto VE table
    By ippielb in forum Gen III V8 Specific
    Last Post: May 31st, 2011, 01:09 PM
  3. Replies: 1
    Last Post: October 24th, 2006, 05:54 AM
  4. More idle table questions (answer and win a smiley)
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2005, 05:58 AM
  5. a few questions to answer...any help appreciated
    By The Alchemist in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2005, 09:52 PM
