Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
Thread: Vortec Calc VET Auto Tune, Final Answer!
  1. #21
    Apr 2008
    so can you post the correct calc_pid file ? i use this for ls all the time
    stock sucks
  2. #22
    Quote Originally Posted by EagleMark View Post
    Think I got procedure right. Not sure I have all correct changes done, going to test.
    Understand that I have experiance with sytax from HTML. CGI etc... and learning how/what/why these entries work.
    Looks ok...
    do you realize that CALC.LTFTBEN is defined twice...? Delete CLC-00-002 and the PRN that uses it (see attached).
  3. #23
    Lifetime Member EagleMark's Avatar
    Dec 2010
    I will if you want to play and help, but this is strictly beta, I have no idea if anything is accurate. Right now I have data spitting out the MAPs several ways, even WB.
    Biggest issue the entire time was no Commanded AFR. Right now I'm using a PID named LS2 (read earlier posts), so we need to make sure it is accurate as well.
    Have to use Commanded Air Fuel Ratio B LS-2 GM.AFR_B
  4. #24
    Dec 2010
    Looks ok...
    Yup, Thanks Joe, I caught that as soon as I connected to the truck.
    Look up one post and see if that calc_pid-Vortec-Bets has all it needs for other WB stuff for me please?
  5. #25
    Good to know, I wonder if the P10 uses GM.AFR_B as its commanded AFR PID instead of GM.AFR...hmmm. But it has a problem that the VE tables are Load % vs RPM (hybrid SD/alpha-n fueling) and the Load PID doesnt work.
  6. #26
    calc_pids-Vortec-Beta.txt looks good and clean... I tried it out and all the calc pids it defines select ok.
  7. #27
    It might use GM.AFR_B... or it might use SAE.LAMBDA.
    Too bad about the load pid... can SAE.MAP be used as load...?
  8. #28
    Dec 2010
    VERIFIED: GM.AFR_B does change commanded AFR when stoichiometric is changed, checked at 14.7 and 14.2, verified both of them through serial WB.
  9. #29
    SAE.LAMBDA reports invalid data last I checked on the P10.
    If I knew how to use SAE.MAP and make a load PID out of that, would make my life easier.
    OK, sorry for the thread hijack EagleMark.
  10. #30
    Dec 2010
    It's OK, I owe you one!
    Had some time to work on this again, got data but some or all not correct at this point. Some things are still missing or done in VE% and for this PCM VE is in g*K/kPa.
    One of the hurdles was already done in another thread by joecar.
    Code:
     *CLC-00-273
    C                  0.0         100.0       .1  "{GM.DYNAIRTMP_DMA.C}"
    F                 40.0         220.0       .1  "{GM.DYNAIRTMP_DMA.F}"
    K                280.0         380.0       .1  "{GM.DYNAIRTMP_DMA.C}+273.15"
    R                500.0         680.0       .1  "{GM.DYNAIRTMP_DMA.F}+459.67"
    Changed to:
    *CLC-00-273
    C                  0.0         100.0       .1  "{SAE.IAT.C}+({SAE.ECT.C}-{SAE.IAT.C})*{CALC.B4901}"
    F                 40.0         220.0       .1  "{SAE.IAT.F}+({SAE.ECT.F}-{SAE.IAT.F})*{CALC.B4901}"
    K                280.0         380.0       .1  "{CALC.DAT.C}+273.15"
    R                500.0         680.0       .1  "{CALC.DAT.F}+459.67"
    With that do the degrees F and C need to be defined in calc_pids file?
    Code:
     *UNITS
    #Code     System     Abbr     Description
    None      None       ""       "No units"
    K         Metric     K        "Degrees Kelvin"
    R         Imperial   R        "Degrees Rankine"
    Some of the Calcs are in VE%? I need VE is in g*K/kPa. So does this need other PIDS or can it be converted?
    Code:
    CALC.VEN                   F300 CLC-00-300   "%,VE"           Tuning           "Calculated VE, not corrected"
    CALC.VET                   F305 CLC-00-305   "%,VE"           Tuning           "Calculated VE, BEN corrected"
    Then there is this issue? This PCM does not have GM.EQIVRATIO, is there another way like the Dynamic air to blend of IAT and ECT with lookup?
    Code:
     *CLC-00-032
    factor             0             4         .0  "{GM.EQIVRATIO}=1"
    *CLC-00-110
    factor             0.5           1.5       .4  "{GM.EQIVRATIO}*{EXT.WO2LAM1}"
    I loaded a butt load of possible PIDs to validate and checked for data on ones that did not validate, here's an idea of what I have to work with. SOme show as valid but still do not put out proper data because of conversions or lack of other PIDs needed. Tried catching up and educating myslf on this but right now I have a headache and going blind looking, need a reality check!
  1. Auto VE or Calc VET or Auto Maf?!?!
    By Nver2loud in forum Gen III V8 Specific
    Last Post: October 23rd, 2012, 05:08 AM
  2. Cannot get the PID's for either Calc or Auto VE table
    By ippielb in forum Gen III V8 Specific
    Last Post: May 31st, 2011, 02:09 PM
  3. Replies: 1
    Last Post: October 24th, 2006, 06:54 AM
  4. More idle table questions (answer and win a smiley)
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2005, 06:58 AM
  5. a few questions to answer...any help appreciated
    By The Alchemist in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2005, 10:52 PM
