Results 1 to 4 of 4
Thread: Locked Out!
    Oct 2005
    Default Locked Out!
    I had locked the PCM before taking the AV for some warranty work(trim items). Did several reflashes after that. It has been sitting for a couple of months with the battery disconnected. I finally have the new tranny in, new fuel system and 90mm TB installed so it's time for some tuning. I have the preliminary tune ready to flash but now the PCM won't recognize my unlock key! Any ideas?
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
    Find the file called \My Documents\EFILive\V7\Bins\PCMLocks.ini
    Open the file using NotePad, find the PCM serial number that matches the locked PCM.
    Send your FlashScan serial number and the seed/key values from the file to me (paul@efilive.com) and I will send you back the key to unlock your PCM.
    Oct 2005
    Email sent.
    Thanks Paul
    Oct 2005
    That did the trick.
    Thanks again.
  1. I Locked PCM but now have new V2
    Last Post: September 16th, 2008, 01:13 PM
  2. locked ECM
    By duramaxdaddy29 in forum Duramax LB7
    Last Post: June 4th, 2008, 05:30 PM
  3. E40 ECM locked
    By LBZ_YFZ in forum Gen IV V8 Specific
    Last Post: April 4th, 2008, 01:37 PM
  4. Locked PCM?
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: March 16th, 2006, 01:46 PM
  5. 98's (Locked)
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2005, 09:54 AM
