Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: dword value translate into real
  1. #21
    The machine I tested it on was: Windows 7 64-bit Intel i7 dual 3.4GHz, 12GB RAM, so I don't think it is the speed of the computer that is causing the problem.
    The only setting that controls the playback speed is shown below:
  2. #22
    Jan 2012
    Paul next guy wanna know if the injection time is this right here:
    * 11 OLDRFPER TIME BETWEEN REFERENCE PULSES (MSB)
    * 12 +1 OLDRFPER TIME BETWEEN REFERENCE PULSES (LSB)
    ************************ MSEC = ([N11] * 256 + [N12]) / 65,536
    This information is contained in A135.DS that matches my powerful Chevrolet Kadett GL 1.8 EFI Petrol.
    I mounted the macro and now need to make sure if that's right. As to factor too have doubts, did seguite:
    TI = ((11 * 256) + 12) / 65536, the result was 0.043151855. Is that correct?
    I ask this because I want is to calculate consumption liters per hour and according to information I passed the time should be used for injection.
    Besides, you know the formula to calculate the consumption of liters per hour at injection time?
    Thanks!
  3. #23
    "Reference Pulses" refers to the pulses from the crank sensor on the flywheel and is used to calculate RPM.
    It provides a higher resolution signal than the previous byte, which only shows RPM in increments of 25.
    The formula is actually
    ((11*256)+12)*65.536 (sixty-five point five three six) = 43.151855
    To convert references pulses to RPM you need to do this (assuming the crank trigger has 60 teeth):
    One complete revolution will take 43.151855*60 teeth = 2589ms
    So in 1 millisecond the crank will complete 1/2589 revolutions.
    Multiply that by 60,000 to convert milliseconds to minutes and get rpm = 23 rpm
    23 rpm seems a bit low so maybe your crank does not have 60 teeth.
    Injector pulse width is defined here:
    36 BPW BASE PULSE WIDTH (MSB)
    37 BPW+1 BASE PULSE WIDTH (LSB)
    mSEC = ([N36]*256 + [N37])/65.536
    To convert from pulse width to fuel flow in liters you must know the "flow rate" of your injectors.
  1. Real lean at WOT or WB ?
    By maudyZ28 in forum Gen III V8 Specific
    Last Post: September 10th, 2012, 08:30 AM
  2. Real Time
    By BadLSX in forum Gen III V8 Specific
    Last Post: June 7th, 2012, 03:16 PM
  3. real time VE
    By myws6formula in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 14th, 2012, 02:48 PM
  4. Real lean then real rich when zipping the throttle...
    By LS1_Dragster in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2011, 09:23 AM
