Set B3609 to zeros.
B3616 is set to enable PE at 35% all across... do you want it to enable so easily below 3000 rpm...?
B5913 and B5914 are identical, nulls out knock retard feature, are you sure you want this...?
Set B3609 to zeros.
Yes I did that before I went to COS5 and got them close before I started getting into boost.
What would be a good safe starting point on B3616?
Is there a way to get the engine CC to be remimbered and not have to enter it for every log. I've done logs and forgot to put it in and all you get is zeros.
