Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 84
Thread: CALC.PIDs
  1. #11
    Nov 2012
    yep I had to find it and now it works
    Quote Originally Posted by Rich Z View Post
    I'm glad a read this, otherwise I would have gotten bitten by the same thing. Is this CALC.DAT actually missing in the two tutorials I have been using, and I just overlooked it?
  2. #12
    CALC.DAT is in the Calc.VET thread.
  3. #13
    Nov 2012
    I just looked three more times I still don't see it?
  4. #14
    CALC.DAT is contained in the calc_pids.txt file in post #1 of the Calc.VET thread...
    I. SERIAL WIDEBAND USERS (REQUIRES V2)
    1.
    Setup Calculated PIDS
    calc_pids.txt <--- updated calc_pids.txt file
    Copy that calc_pids.txt file to this location (or copy/paste its contents to the file at this location on your PC):
    My Documents\EFILive\V7.5\User Configuration\calc_pids.txt
    A-New-Twist-on-CALC-VE-Table-Computing-the-Entire-VE-Table
  5. #15
    Nov 2012
    OK yes it is in the text but if its not in the pids slected CalculatedVE, Not corrested does not work.
  6. #16
    Lifetime Member Rich Z's Avatar
    I think the point trying to be made is that unless I missed it, this CALC.DAT is not mentioned in the tutorial (at least the PDF version I am using) at all, yet appears to be necessary for this procedure to work. The presumption of a tutorial is that someone using such a document probably doesn't know what they are doing (certainly true in my case) and therefore and errors or omissions are going to throw us for a loop, because what we are trying to learn just will not work. So is such a tutorial really helping newbies all that much?
    CorvetteFlorida.com
    2002 Corvette Z06
    427 RHS block built by LME
    STS rear mounted twin turbos
    It nearly died on the operating table, but I'm bringing her back.
  7. #17
    If CALC.VET and/or CALC.VEN have a red X thru them (on the PIDs tab), then do this:
    on each of the pids that has a red X do rightclick->More Info
    this will tell you why the pid is invalid (red X), it will tell you which other pid has not been selected...
    you then select that other pid and repeat the process.
  8. #18
    Yes, maybe CALC.DAT is not mentioned in the tutorial, but the tutorial does mention dynamic air temperature (in the form of the pid GM.DYNAIRTMP_DMA)...
    and when you study the pid CALC.VET in calc_pids.txt you will see that it uses CALC.DAT....
    [ do not go blindly by what a tutorial says... but rather analyze/question why/what is going on until you understand it ]
  9. #19
    Quote Originally Posted by COONDOG96 View Post
    Post a screenshot.
    BTW: the pids you should be using are CALC.VET and CALC.VEN... and not CALC.VE.
  10. #20
    Lifetime Member EagleMark's Avatar
    Dec 2010
    Good advice!
    I think what happened in this new twist was this was an addition to origanal Calc VE that is under help and tutorials. Do that one first and then read the twist and it all comes together. But they are both differant. So you may get more confused before it comes clear.
  1. calc pids for autometer
    By chevylq9 in forum Gen III V8 Specific
    Last Post: July 10th, 2011, 06:33 PM
  2. Can someone help me out with calc.pids
    By pavetim in forum Gen III V8 Specific
    Last Post: January 24th, 2011, 04:30 AM
  3. Calc Pids
    By minytrker in forum External A/D inputs
    Last Post: February 19th, 2010, 04:39 AM
  4. Missing calc.pids
    By VetPet in forum General
    Last Post: December 4th, 2005, 03:01 PM
  5. CALC pids
    By purrvert in forum General
    Last Post: October 24th, 2005, 11:32 PM
