Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 84
Thread: CALC.PIDs
  1. #61
    Set B3609 to zeros.
    B3616 is set to enable PE at 35% all across... do you want it to enable so easily below 3000 rpm...?
    B5913 and B5914 are identical, nulls out knock retard feature, are you sure you want this...?
  2. #62
    Quote Originally Posted by slows10 View Post
    Thanks wolfie. I Typed a 5 minute response to your post. Looks like the higher ups keep deleting it. Joecar?? come on man.
    I didn't delete anything...!?
    ( I don't see any posts being deleted from here )
  3. #63
    Quote Originally Posted by COONDOG96 View Post
    Here is my last log I put COS5 in so I can do some boost logs for CALC.VET. This is the last log I have not loadedit yet does it look right.
    The Cal I put in it.
    Have you created the SELBEN B5001 map and the VET B0101 map and applied them...?
  4. #64
    May 2010
    Ok no problem just seemed strange.
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
  5. #65
    May 2010
    Ah it wasnt worth any one reading anyway I guess.
  6. #66
    I've deleted a couple of spam posts in this thread - but they were in Vietnamese - you weren't replying in Vietnamese were you?
  7. #67
    Nov 2012
    Yes I did that before I went to COS5 and got them close before I started getting into boost.
  8. #68
    Nov 2012
    What would be a good safe starting point on B3616?
  9. #69
    For boost, something like 1.25 EQ... if your MAF/VE are correct.
  10. #70
    Nov 2012
    Is there a way to get the engine CC to be remimbered and not have to enter it for every log. I've done logs and forgot to put it in and all you get is zeros.
  1. calc pids for autometer
    By chevylq9 in forum Gen III V8 Specific
    Last Post: July 10th, 2011, 07:33 PM
  2. Can someone help me out with calc.pids
    By pavetim in forum Gen III V8 Specific
    Last Post: January 24th, 2011, 05:30 AM
  3. Calc Pids
    By minytrker in forum External A/D inputs
    Last Post: February 19th, 2010, 05:39 AM
  4. Missing calc.pids
    By VetPet in forum General
    Last Post: December 4th, 2005, 04:01 PM
  5. CALC pids
    By purrvert in forum General
    Last Post: October 25th, 2005, 12:32 AM
