Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 84
Thread: CALC.PIDs
  1. #71
    Lifetime Member EagleMark's Avatar
    Dec 2010
    In Scantool, Edit, Default Customer details and fill it in.
  2. #72
    Nov 2012
    I have done that 5 or 6 times but its allways blank when I go to do the next log. If I forget the log is junk all zeros.
    Quote Originally Posted by EagleMark View Post
  3. #73
    Dec 2010
    Hmmm.. I had that issue and I thought that was the fix? It may be differant PIDS selected, I always use one PID file now and don't have the issue anymore.
    What data are you missing that this is needed for? IIRC if it was done to % CC or displacment was needed but if done to VE it was not... Joe will be up soon to help.
  4. #74
    I avoid engine displacement altogether by using [g*K/kPa] for VE units... (I completely avoid [%] units).
  5. #75
    i.e. goto Edit->Properties and set the VE units to g*K/kPa
    and in the scantool, use the CALC.VET/VEN pids with units g*K/kPa (abbreviated "VE").
  6. #76
    Nov 2012
    THANKS DID THAT NOW IT ALL BETTER!!! Here are my last to logs open for all advice I know that I probly have something set wrong. The truck seems to be running better but still getting KR when I roll into it at low RPMs. Trying to get it close so I can take it to the dinno to get the final timing and boost right without taking all day$$$$$$$ Thanks again.
  7. #77
    Nov 2012
    logs
  8. #78
    Dec 2010
    Ah! Now I remeber when you told me the same thing!
  9. #79
    lol.
  10. #80
    The default engine size (and other vehicle specific data) can be entered under customer details for each unique VIN.
    i.e. Edit->Default Customer Details.
  1. calc pids for autometer
    By chevylq9 in forum Gen III V8 Specific
    Last Post: July 10th, 2011, 07:33 PM
  2. Can someone help me out with calc.pids
    By pavetim in forum Gen III V8 Specific
    Last Post: January 24th, 2011, 05:30 AM
  3. Calc Pids
    By minytrker in forum External A/D inputs
    Last Post: February 19th, 2010, 05:39 AM
  4. Missing calc.pids
    By VetPet in forum General
    Last Post: December 4th, 2005, 04:01 PM
  5. CALC pids
    By purrvert in forum General
    Last Post: October 25th, 2005, 12:32 AM
