Results 1 to 4 of 4
Thread: Weird problem with Rev Limiter
    Nov 2009
    Default Weird problem with Rev Limiter
    i set my Rev Limiter to 7000 rpm
    the problem the car when it's in gear 5 does the cut off at 5700 Rpm, is that from the torque reduction
    the file for the car and the log are attachment
    what do u think guys ,,
    Lifetime Member Rhino79's Avatar
    Jul 2006
    Might have a look at D9420 in the tcm, fifth and sixth values are 0 on the high side of the table. Other than that, make sure the ecm and tcm have correct gear settings in all fields.
    Head Calibrator
    Gwatney Performance Innovation
    Jacksonville, AR 501-982-2102
    Nov 2009
    i will try
    the thing with D9420 the maximum rpm is 3000
    Jul 2006
    It will use that last row for calculation above that rpm if Im not mistaken though.
    Head Calibrator
  1. Help Please, on the dyno and rev limiter like problem at ~4600
    By johnmaster in forum Gen III V8 Specific
    Last Post: September 6th, 2012, 08:40 AM
  2. Weird E40 05 Vette rev limiter fix
    By 9secVette in forum Gen IV V8 Specific
    Last Post: August 11th, 2010, 03:07 AM
  3. Rev limiter help
    By Badmire68 in forum Gen III V8 Specific
    Last Post: January 17th, 2008, 10:53 AM
  4. rev limiter
    By CWR in forum Vortec V6/V8 Specific
    Last Post: July 4th, 2007, 05:40 PM
  5. Rev limiter problem?
    By 67SS509 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 22nd, 2006, 05:51 AM
