i set my Rev Limiter to 7000 rpm
the problem the car when it's in gear 5 does the cut off at 5700 Rpm, is that from the torque reduction
the file for the car and the log are attachment
what do u think guys ,,
Might have a look at D9420 in the tcm, fifth and sixth values are 0 on the high side of the table. Other than that, make sure the ecm and tcm have correct gear settings in all fields.
Head Calibrator
Gwatney Performance Innovation
Jacksonville, AR 501-982-2102
i will try
the thing with D9420 the maximum rpm is 3000
It will use that last row for calculation above that rpm if Im not mistaken though.
Head Calibrator
