Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Scan Tool Error
    Jun 2009
    Default Scan Tool Error
    Today when i tried connecting to my 2002 chevy silverado 5.3l I kept getting an error. I know before in the past i have been able to log on this vehicle but today i kept the error attached. Scan tool was showing i was connected, but it didn't seem like it was. Then when I clicked on the yellow button to start monitoring this is when the error was generated. So what is going on and how to I fix this?
    gpr, thanks, I forwarded the error report to Paul.
    Its a problem caused by the FlashScan firmware misinterpreting the A/D input values when no A/D voltage is applied. It will be fixed in the next software/firmware update.
    Using one of the orange A/D connectors, try making a loopback connection to AD1 that simply connects both pins of the AD1 input together. That will hopefully pull the AD input signal down low enough to prevent it interfering with the data logging.
    So would he see this because he has the analog pids automatically selected...?
    That would probably solve the problem as well.
    gpr,
    if you're not using the analog interface, start V8 S&T, goto F6: Devices, goto F6: Logging, and uncheck Automatically select ALL external analog pids;
    then Save to file (Settings.dat) and Program to V2.
    Jun 2009
    I will give that a try and turn off the analog interface. How come I get this error on the pickup, but when I plug it into my 2002 camaro I don't have any problems? It is same pcm.
    I know I have updated software and firm ware on the v2 since I last tried to log data on this pickup.
    Thanks for the quick responses and help!
    The error occurs (or does not occur) based on the voltage that the FlashScan firmware detects on the A/D input. If nothing is connected then that value can fluctuate based on the general electrical conditions in the vehicle and or in FlashScan. I presume that can be different for different vehicles. Adding the loop back connection should stop that value from fluctuating randomly. Or as Joe suggested not logging those values may prevent the firmware and/or software from attempting to process the fluctuating values.
    The problem is not really that the A/D voltages fluctuate when nothing is connected, its that the firmware and software are processing the A/D data incorrectly and a side effect of not having anything connected causes the firmware/software to process the data incorrectly. That will be fixed in the next update.
    Reagrds
    Jun 2009
    I went into the settings on the v8 S&T but all check marks were already unselected, so i programmed the v2 anyway. It fixed the problem. Thanks for the help guys.
    From another thread:
    Please see this thread.
    http://forum.efilive.com/showthread.php?20725-Scan-Tool-Error
    Because you are using the analog/external PIDs and deselecting them is not an option, you will need to create a loopback link for AD1 to force the A/D counts for AD1 to be zero.
    Then you'll need to hook up the wideband to AD2, and use the AD2 PIDs for wideband logging.
    It is fixed in the next update. That update was due out earlier this week but some last minute problems appeared in final testing and they are still being fixed.
    It may be another week before it is ready.
  1. V7.5 Scan tool error
    By jay p in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 8th, 2012, 06:19 AM
  2. getting an error trying to read bbl on scan tool
    By Aint Skeered in forum FlashScan V2 BB Logging
    Last Post: June 4th, 2008, 07:13 AM
  3. Replies: 4
    Last Post: January 6th, 2008, 11:47 AM
  4. Fit to Scan Tool/Tune Tool
    By limited cv8r in forum General
    Last Post: March 3rd, 2007, 06:10 AM
