Results 1 to 5 of 5
Thread: Boost tables - mm3 per stroke?
    Dec 2005
    Default Boost tables - mm3 per stroke?
    In the boost tables what is the mm3 per stroke referring to?
    EFILive Reseller
    Nov 2005
    Fuel delivery rate.
    www.kennedydiesel.com
    Specializing in Duramax Performance
    More than just a salesman-I use and test the products that I sell on a daily basis.
    Superflow Lie Detector in house
    Dec 2005
    What does the Green/Yellow/Red mean on the charts?
    Senior Member Racehemi's Avatar
    Nov 2005
    Red refers to high values, green is low, yellow is in between.
    04 2500, LLY/A, 4x4, CC, SB, 285 Toyo's, Amsoil lubes, Access Roll-up Tonneau, ATS Stage 2 trans, ATS 5 Star Converter, Bilstein's, Caltracs bars, Cognito Braces, EFILive, Kennedy Diesel Custom Tuning, Kennedy Diesel headlight harness, Kennedy Dual Lift Pump/Filter combo, Prodigy brake controller, Spa DG 211, Trippin Cyclops overhead gauge mount, , TTS 4" Exhaust, TTS Xtreme Beta, Amsoil Ea filters, Banks CAI
    Quote Originally Posted by turbo lcc
    They are not 'warnings', Red doesn't mean danger, it just gives you a nice visual idea of the values. Oh, you can change those colors if you wish.
    Cheers.
  1. LMM OS 12628594 boost tables
    By GMPX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 28th, 2010, 08:23 AM
  2. DURAMAX lly Boost tables
    By Banshee1973 in forum Duramax LLY
    Last Post: March 18th, 2010, 02:35 PM
  3. Boost fueling tables
    By limited cv8r in forum Custom Operating Systems
    Last Post: March 17th, 2009, 04:17 PM
  4. lbz boost tables
    By dynarex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 28th, 2007, 01:54 PM
  5. ECT Boost tables inop
    By killerbee in forum Duramax LLY
    Last Post: February 17th, 2007, 12:24 PM
