Results 1 to 10 of 17
Thread: Error message speedo calibration
    May 2008
    Default Error message speedo calibration
    I keep getting this error message when I goto calibrate a speedo and the Speedo fine tuning does not sem to work. any Ideas?
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    Your Windows login account does not have sufficient privileges to write a file to a system folder...
    Feb 2013
    I'm reviving this thread because I'm getting the same message, what exactly do you mean by this?
    The tune i'm working on is from a 98 ls1 trans am. I'm also getting another error message that says "Tire diameter cannot be calculated because diff ratio is zero."
    When you log in to Windows, if you're not Admin then you have limited privileges (you won't be allowed to write files in the Program Files folder)...
    when EFLive tunetool performs certain specific functions (like speedo calibration shown above) it writes a file in the Program Files folder...
    but if you don't have Admin privileges then Windows prohbits the file write...
    so either you have to login as Admin or you have to otherwise assign sufficient privileges to your login (typically via Admin).
    Post a screenshot showing the differential ratio being zero...
    a non-zero differential ratio is required in order to calculate tire diameter (to avoid divide-by-zero).
    Feb 2013
    Feb 2013
    Feb 2013
    Here are the screenshots, the first is where it says it cannot be calculated because the diff ratio is zero.
    The second screenshot is where it says "cannot create file/Access is denied" just like the op's problem.
    I checked the settings on my computer and it is set to admin.
    I pm'd Tech Support.
    Quote Originally Posted by reytx1 View Post
    You still have a permissions restriction. Using Windows explorer, navigate to the folder:
    C:\Program Files\EFILive\V7.5 (if that is where EFILive V7.5 is installed) and right click on the right hand side where the file names are listed and select New->Text Document.
    If you can create a new text document then your permissions are ok, if you cannot create the text document then you do not have permission to create files in that folder. That also means EFILive will not have permission to create its files in that folder.
    Chances are the right-click "New" submenu will only have "Folder" in it, meaning you can only create folders and not any other type of file.
  1. Holden Speedo calibration
    By rally1 in forum E37, E38 & E67 PFI ECM's
    Last Post: October 19th, 2010, 12:57 PM
  2. Speedo calibration VSS in Scan not same as speedo
    By maudyZ28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 23rd, 2010, 01:47 PM
  3. Error message?
    By nathans1987 in forum Custom Operating Systems
    Last Post: September 2nd, 2009, 02:04 PM
  4. Calculated VSS (used to verify speedo calibration)
    By joecar in forum Tips and tricks
    Last Post: January 19th, 2006, 04:18 PM
  5. Speedo Calibration
    By Mark Barber in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2005, 02:32 PM
