Results 1 to 10 of 13
Thread: Cannot Connect
    Jan 2013
    Default Cannot Connect
    Sorry if this has been asked before, i did try searching first. I am a first time user of EFILive and am trying to see what DTCs my VSV6 throws at me. My problem is, when i try to connect, it says all 8 of the comm port options are wrong and will not let me connect my laptop to my car. I may be setting something wrong, i have tried reading through the help sections, but if i keep going, i wont have a laptop to look at my DTCs on LOL. Please, any help would be great, and since im very new to this stuff, the most lamen of terms would be amazing LOL cheers
    Are you using a serial to USB converter? If so (and assuming it will work with the ALDL protocol) you'll need to find out which serial port the USB converter is using.
    Press and hold the Windows Key (between the Ctrl and Alt Keys) and while holding the Windows Key, press and release the Pause button (near the numeric keypad).
    That will display the Computer Properties window.
    On Windows XP:
    Select Hardware tab page
    Click on the [Device Manager] button
    On Windows Vista and 7:
    Select Device Manager
    For all Windows:
    Expand the Universal Serial Bus Controllers item (that will be at the bottom of the list)
    Look for your USB-Serial converter device, right click it and select Properties.
    Look through the various settings and one of them should show you which serial port number the converter is using.
    Configure that COM port setting in EFILive.
    Jan 2013
    Mine does not show it. Mine has lost of host controllers, a composite device and lots of root hubs. I'm prob reading it wrong or doing something wrong :(
    Unplug the USB-serial device and press F5 and see which device disappears.
    And/or plug it back in and press F5 and see which device re-appears.
    Jan 2013
    Cheers, lol I wouldn't of thought of that, ill try in a few when I get back to laptop. If not maybe I'm missing something, I have obd plug to USB inserted from car to laptop. Just to check and clear codes. Is there more hardware I need?
    Jan 2013
    well i have just realised what part of the issue may be, when i plug in the cable a new option appears under the "other" section of device manager and comes up as driver unavalable. when i try to update the driver it will only search my computer and not give the option to search online for it, where would i get the driver needed for it to recognise the ALDL cable being plugged in? cheers
    Quote Originally Posted by greggles_vs View Post
    It is unlikely that the drivers would be found by Windows searching Microsoft's driver database.
    Did the cable come with a CD that had drivers on it? Or maybe go to the cable manufacturer's web site and look for a downloads section that may have drivers available.
    Just for interest who manufactured the cable you are using?
    Jan 2013
    It was a purchase from eBay, my mate bought the cable and lent it to me, so I'm not entirely sure as there is no stickers on it. It was ment to come with full version of efilive4 and tunerpro rt however it was a burnt disc with a free copy of tunerpro rt. The cable is a blue cable with a red light on the obd plug
    Many USB/ALDL cables use the FTDI chipset.
    Download the USBView program from here:
    http://www.ftdichip.com/Support/Utilities/usbview.zip
    Run it and look for your device and see what the manufacturer (of the USB chipset) is listed as.
    For example here's EFILive's old V1 cable showing that the USB chipset is supplied by FTDI.
    If you only get a vendor ID and no description you can look it up.
    For example in the USBView image above the Vendor ID (VID) is 0x0403(hex)=1027(decimal) you can look it up in the list on this page:
    http://www.usb.org/developers/tools/ click on the "Company List" link and choose to open it using "Windows Word Pad".
    Jan 2013
    Thats what i get when i open that file you said about, sorry, i used to be better PC minded but lost my touch when havent had internet for ages.
  1. cant connect Vt V6
    By aka_n0j in forum EFILive V4
    Last Post: July 3rd, 2011, 10:27 AM
  2. Can't get LC-1 to connect
    By pavetim in forum FlashScan V2
    Last Post: February 13th, 2011, 07:26 PM
  3. can not connect
    By Jetmech in forum General (Diesel)
    Last Post: November 29th, 2010, 08:31 AM
  4. v4 cant connect
    By stevedarman in forum EFILive V4
    Last Post: November 5th, 2010, 08:11 PM
  5. Help please trying to connect
    By 5.7senator in forum EFILive V4
    Last Post: November 21st, 2009, 10:02 AM
