I cant find what is causing the low timing in this tune. I have set all of the cells I should be in in PE to 22 degrees as a starting point and zeroed out burst knock but i am still getting timing as low as 5 degrees and it will stay between 10-17 through most of the pull. attached is a log and the tune file.
Thanks for any help
