Diesel guy you are using V7 red Max you are using V8 that's why it looks different. Read Max use the seven it will More likely to go through First you need to disconnect batteries then reconnect then full flash with V7
http://www.duramaxdiesels.com/forum/...rgency+relearn
this is the link if you have more questions on that relearn process.
Just some guy
ya all i use is v7.5 guess i dont change if something is working for me.
Just some guy
We will do a bench analysis and reflash if needed. If it is salvageable, the cost is minimal.
Custom Tuning Services
