Post a screenshot of the map and of the filter.
Goto the PIDs tab and see if the pids CALC.SELBEN, CALC.VET, CALC.VEN have a red X thru them... post a screenshot.
Also:
Did you select the pid CALC.DAT...? Your log file shows it's not selected...
with the log file open, on the pids select CALC.DAT, and save the log file (File->Save As).
Trey using this filter:
paste that into the file Filters.txt located in the User Configuration folder.Code:[TRANSIENT FILTER] Filter=Inclusive X0000=SAE.ECT,F,°F,GT,176.00,100,AND X0001=SAE.RPM,rpm,RPM,GT,500.00,100,AND X0002=SAE.TP,%,%,GTEQ,1.00,100,AND X0003=SAE.TP,%,%,DXLT,5.00,100,
Also:
with the log file open, on the pids select CALC.DAT, and save the log file (File->Save As (notice the filename gets a number appended)).
Also in your tune file do this:
- set B3616 to same as 2002 Camaro (65%/35% split),
- set B3609 to all zeros.
B3618 has overly rich parts... will you be running boost...?
