Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 50
Thread: Trouble communicating
  1. #11
    Jan 2013
    Sorry about that Paul, I saved it as JPEG, re-saved as a PNG
    It's sending and receiving, and max echo is seen to start, You can also see in the image that T6 was 200ms, but wasn't working (no chatter detected). It hinted to change it to 100ms, so I did. Here's the text of the error that just keeps repeating at 100ms.
    10:02:923 Com timeout: Data frame truncated: $01,$D1,$56,$08,$AE,$C0,$49,$FC,$10,$59,$0A,$3D,$0 0,$00,$50,$40,$55,$6B,$41,$61,$00,$20,$00,$3D,$3D, $01,$00,$00,$00,$7A,$00,$2F,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,
    10:02:944 Error:No Echo received from MAX232
  2. #12
    I really need to see the entire text copy/pasted into this thread. A screen shot doesn't give me all the info.
    Right click on the text and select Copy All, then just paste into this thread.
  3. #13
    Jan 2013
    The orginal informatiom was gone but I still had the saved screen shot as an image, couldn't copy/paste text from it. So I just went out and did it again. Here's Corvette_Camaro
    57:36.719: Initialising...
    57:37.366: Opening COM2 8228,8,N,1
    57:37.684: Ready.
    59:03.903: Check vehicle interface...
    59:03.910: Waiting for Aldl bus silence of at least 100ms...
    59:04.102: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    59:04.111: Max232 interface detected OK
    59:04.115: Scanning for heartbeat and chatter frames...
    59:04.115: Waiting for Aldl bus silence of at least 100ms...
    59:06.208: Heartbeat frame:
    59:06.208: 59:04.383: $40,$55,$6B
    59:06.208: Heartbeat frame is followed by 16ms of silence
    59:06.208: Advisable value for T6 is 8ms
    59:06.208: Chatter frame(s):
    59:06.208: 59:04.399: $41,$61,$00,$20,$00,$42,$41,$01,$00,$00,$00,$7A,$0 0,$38,$08
    59:06.208: 59:04.543: $10,$59,$0A,$42,$00,$00,$4B
    59:11.928: Start macro: : ECM
    59:11.924: Synchronising ALDL communications...
    59:11.924: Waiting for heartbeat: $40,$55,$6B
    59:11.924: Waiting for Aldl bus silence of at least 100ms...
    59:12.457: Com timeout: Data frame truncated: $01,$A2,$56,$08,$AE,$20,$27,$C2,$10,$59,$0A,$42,$0 0,$00,$4B,$40,$55,$6B,$41,$61,$00,$20,$00,$42,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00
    59:12.471: Error: No echo received from MAX232
    59:12.474: Send: $F4,$57,$01,$00,$B4
    59:12.578: Recv: $F4,$95,$01,$20,$F9,$00,$00,$00,$00,$00,$12,$20,$2 0,$57,$00,$28,$00,$00,$10,$00,$00,$00,$00,$FF,$42, $F2,$13,$74,$F2,$1E,$25,$66,$66,$80,$80,$00,$00,$0 0,$80,$80,$83,$00,$96,$FF,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 3,$8C,$00,$00,$1A
    59:12.584: Synchronising ALDL communications...
    59:12.584: Waiting for heartbeat: $40,$55,$6B
    59:12.584: Waiting for Aldl bus silence of at least 100ms...
    59:13.081: Com timeout: Data frame truncated: $7A,$7D,$AB,$84,$AE,$10,$59,$0A,$42,$00,$00,$4B,$4 0,$55,$6B,$41,$61,$00,$20,$00,$42,$41,$01,$00,$00, $00,$7A,$00,$38,$08,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00
    59:13.092: Error: No echo received from MAX232
    59:13.095: Send: $F4,$57,$01,$00,$B4
    59:13.186: Recv: $F4,$95,$01,$20,$F9,$00,$00,$00,$00,$00,$12,$20,$2 0,$57,$00,$28,$00,$00,$10,$00,$00,$00,$00,$FF,$42, $F2,$13,$74,$F2,$1E,$25,$66,$66,$80,$80,$00,$00,$0 0,$80,$80,$83,$00,$96,$FF,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 3,$8C,$00,$00,$1A
    59:13.303: Synchronising ALDL communications...
    59:13.303: Waiting for heartbeat: $40,$55,$6B
    59:13.303: Waiting for Aldl bus silence of at least 100ms...
    59:13.658: Com timeout: Data frame truncated: $12,$9F,$15,$21,$8D,$80,$7A,$00,$38,$08,$10,$59,$0 A,$42,$00,$00,$4B,$40,$55,$6B,$41,$41,$01,$00,$00, $00,$7A,$00,$38,$08,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00
    59:13.672: Error: No echo received from MAX232
    59:13.676: Send: $F4,$57,$01,$00,$B4
    59:13.877: Com timeout: Data frame truncated: $08,$F4,$57,$01,$00,$B4,$F4,$95,$01,$20,$F9,$00,$0 0,$00,$00,$00,$12,$20,$20,$57,$00,$28,$00,$04,$10, $00,$00,$00,$00,$FF,$42,$F2,$13,$74,$F2,$1E,$25,$6 6,$66,$80,$80,$00,$00,$00,$80,$80,$83,$00,$96,$FF, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$03,$8C,$00,$00,$16,$F0,$56, $F1,$C9,$10,$59,$0A,$12,$00,$00,$7B,$40,$55,$6B,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00
    59:13.885: Error: No echo received from MAX232
    59:13.893: Recv: $41,$61,$00,$20,$00,$42,$41,$01,$00,$00,$00,$7A,$0 0,$38,$08
    59:13.912: Synchronising ALDL communications...
    59:13.912: Waiting for heartbeat: $40,$55,$6B
    59:13.912: Waiting for Aldl bus silence of at least 100ms...
    59:14.076: Error: Reply frame checksum failure
    59:14.099: Error: No echo received from MAX232
    And here's zr1_1991
    03:15.196: Chatter frame(s):
    03:15.196: 03:13.403: $41,$61,$00,$20,$00,$42,$41,$01,$00,$00,$00,$7A,$0 0,$38,$08
    03:15.196: 03:13.547: $10,$59,$0A,$42,$00,$00,$4B
    03:18.889: Start macro: Engine data: DATA
    03:18.896: Synchronising ALDL communications...
    03:18.896: Waiting for heartbeat: $40,$55,$6B
    03:18.896: Waiting for Aldl bus silence of at least 100ms...
    03:19.416: Com timeout: Data frame truncated: $20,$9F,$15,$21,$4D,$80,$80,$7A,$00,$38,$08,$10,$5 9,$0A,$42,$00,$00,$4B,$40,$55,$6B,$41,$61,$00,$20, $00,$42,$41,$01,$00,$00,$00,$13,$74,$F2,$1E,$25,$6 6,$66,$80,$80,$00,$00,$00,$80,$80,$83,$00,$96,$FF, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$03,$8C,$00,$00,$1A,$10,$59, $0A,$08
    03:19.431: Error: No echo received from MAX232
    03:19.434: Send: $F4,$57,$01,$00,$B4
    03:19.537: Recv: $F4,$95,$01,$20,$F9,$00,$00,$00,$00,$00,$12,$20,$2 0,$57,$00,$28,$00,$00,$10,$00,$00,$00,$00,$FF,$42, $F3,$13,$73,$F2,$1E,$25,$66,$66,$80,$80,$00,$00,$0 0,$80,$80,$83,$00,$96,$FF,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 3,$8C,$00,$00,$1A
    03:19.545: Synchronising ALDL communications...
    03:19.545: Waiting for heartbeat: $40,$55,$6B
    03:19.545: Waiting for Aldl bus silence of at least 100ms...
    03:19.825: Error: Reply frame checksum failure
    03:19.840: Error: No echo received from MAX232
    03:19.844: Send: $F4,$57,$01,$00,$B4
    03:19.937: Recv: $F4,$95,$01,$20,$F9,$00,$00,$00,$00,$00,$12,$20,$2 0,$57,$00,$28,$00,$00,$10,$00,$00,$00,$00,$FF,$42, $F3,$13,$74,$F2,$1E,$25,$66,$66,$80,$80,$00,$00,$0 0,$80,$80,$83,$00,$96,$FF,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 3,$8C,$00,$00,$19
    03:19.944: Synchronising ALDL communications...
    03:19.944: Waiting for heartbeat: $40,$55,$6B
    03:19.944: Waiting for Aldl bus silence of at least 100ms...
    03:20.414: Com timeout: Data frame truncated: $20,$A2,$56,$08,$AE,$20,$20,$40,$2F,$60,$4E,$C6,$1 0,$59,$0A,$42,$00,$00,$4B,$40,$55,$6B,$41,$61,$20, $00,$42,$41,$01,$00,$00,$00,$13,$74,$F2,$1E,$25,$6 6,$66,$80,$80,$00,$00,$00,$80,$80,$83,$00,$96,$FF, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$03,$8C,$00,$00,$1A,$10,$59, $0A,$08,$00,$00,$85
    03:20.431: Error: No echo received from MAX232
    03:20.435: Send: $F4,$57,$01,$00,$B4
    03:20.535: Recv: $F4,$95,$01,$20,$F9,$00,$00,$00,$00,$00,$12,$20,$2 0,$57,$00,$28,$00,$00,$10,$00,$00,$00,$00,$FF,$42, $F2,$13,$73,$F2,$1E,$25,$66,$66,$80,$80,$00,$00,$0 0,$80,$80,$83,$00,$96,$FF,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 3,$8C,$00,$00,$1B
    03:20.649: Synchronising ALDL communications...
    03:20.649: Waiting for heartbeat: $40,$55,$6B
    03:20.649: Waiting for Aldl bus silence of at least 100ms...
    03:21.023: Com timeout: Data frame truncated: $00,$F4,$56,$08,$AE,$01,$00,$00,$00,$7A,$00,$38,$0 8,$10,$59,$0A,$42,$00,$00,$4B,$40,$55,$6B,$41,$61, $00,$20,$00,$42,$41,$01,$00,$13,$74,$F2,$1E,$25,$6 6,$66,$80,$80,$00,$00,$00,$80,$80,$83,$00,$96,$FF, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$03,$8C,$00,$00,$1A,$10,$59, $0A,$08,$00,$00,$85,$40,$55,$6B,$41,$61,$00,$20,$0 0,$42,$41,$01,$00,$00,$00,$7A,$00,$38,$08,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00
    03:21.039: Error: No echo received from MAX232
    03:21.044: Send: $F4,$57,$01,$00,$B4
    03:21.143: Recv: $F4,$95,$01,$20,$F9,$00,$00,$00,$00,$00,$12,$20,$2 0,$57,$00,$28,$00,$00,$10,$00,$00,$00,$00,$FF,$42, $F3,$13,$74,$F2,$1E,$25,$66,$66,$80,$80,$00,$00,$0 0,$80,$80,$83,$00,$96,$FF,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 3,$8C,$00,$00,$19
    03:21.159: Synchronising ALDL communications...
    03:21.159: Waiting for heartbeat: $40,$55,$6B
    03:21.159: Waiting for Aldl bus silence of at least 100ms...
    03:21.422: Error: Reply frame checksum failure
    03:21.440: Error: No echo received from MAX232
  4. #14
    Jan 2013
    Hey Paul I saw another thread about EFI University, but it was from awhile ago. Do you still have classes? I could use them if you still offer them.
  5. #15
    Ok, we need to go back to square one.
    Can you hook up to the vehicle and select ALDL->Listen to Chatter.
    Allow the software to listen to about 20 seconds of chatter and then copy/paste that data into the thread.
    Once I can see the entire chatter cycle, I should be able to tell you the correct settings.
  6. #16
    Quote Originally Posted by vilant View Post
    EFI University is a company that specializes in teaching EFI calibration.
    http://www.efi101.com/efilive.html
    They offer an EFILive intro course that teaches you how to use EFILive's tuning tool software to tune EFI controllers. They do not offer any courses on the EFILive V4 scan tool software. The EFILive scan tool referred to in their literature means the EFILive V7 OBDII scan tool, which has nothing to do with the V4 software.
  7. #17
    Note that EFI University is not affiliated with EFILive... they may teach stuff regarding EFILive, but they are not associated with EFILive.
  8. #18
    Jan 2013
    Thanks for EFI U. info, fellas. Just figured if there was a class on configuring V4, I could do it myself instead of bothering you guys with it. I don't like being a pest. Well, I've got the list from listen to chatter. I'm still not sure which vehicle file I should be using, but I'm leaning towards zr1_1991 (even though mine's a '90). The engines are completely different between a '90 Corvette and '90 ZR-1, but I'm not sure if that matters. Here's zr1_1991
    43:09.127: Initialising...
    43:09.387: Opening COM2 8228,8,N,1
    43:18.770: Ready.
    45:02.570: Scan for chatter...
    45:02.570: Waiting for Aldl bus silence of at least 16ms...
    45:02.778: (45:02.778)$10,$59,$0A,$86,$00,$00,$07
    45:02.810: (45:02.794)$40,$55,$6B
    45:02.826: (45:02.811)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:02.970: (45:02.970)$10,$59,$0A,$86,$00,$00,$07
    45:03.002: (45:03.002)$40,$55,$6B
    45:03.018: (45:03.003)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:03.178: (45:03.178)$10,$59,$0A,$86,$00,$00,$07
    45:03.210: (45:03.194)$40,$55,$6B
    45:03.226: (45:03.212)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:03.370: (45:03.370)$10,$59,$0A,$86,$00,$00,$07
    45:03.402: (45:03.402)$40,$55,$6B
    45:03.418: (45:03.404)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:03.546: (45:03.546)$F0,$56,$F1,$C9
    45:03.594: (45:03.578)$10,$59,$0A,$86,$00,$00,$07
    45:03.611: (45:03.610)$40,$55,$6B
    45:03.627: (45:03.612)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:03.787: (45:03.787)$10,$59,$0A,$86,$00,$00,$07
    45:03.819: (45:03.803)$40,$55,$6B
    45:03.835: (45:03.820)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:03.995: (45:03.979)$10,$59,$0A,$86,$00,$00,$07
    45:04.011: (45:04.011)$40,$55,$6B
    45:04.027: (45:04.012)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:04.187: (45:04.187)$10,$59,$0A,$86,$00,$00,$07
    45:04.219: (45:04.203)$40,$55,$6B
    45:04.235: (45:04.220)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:04.395: (45:04.379)$10,$59,$0A,$86,$00,$00,$07
    45:04.411: (45:04.411)$40,$55,$6B
    45:04.427: (45:04.412)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:04.571: (45:04.555)$F0,$56,$F1,$C9
    45:04.603: (45:04.587)$10,$59,$0A,$86,$00,$00,$07
    45:04.619: (45:04.619)$40,$55,$6B
    45:04.635: (45:04.620)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:04.795: (45:04.795)$10,$59,$0A,$86,$00,$00,$07
    45:04.827: (45:04.827)$40,$55,$6B
    45:04.843: (45:04.828)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:05.003: (45:04.987)$10,$59,$0A,$86,$00,$00,$07
    45:05.019: (45:05.019)$40,$55,$6B
    45:05.035: (45:05.021)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:05.195: (45:05.195)$10,$59,$0A,$86,$00,$00,$07
    45:05.227: (45:05.227)$40,$55,$6B
    45:05.243: (45:05.230)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:05.403: (45:05.387)$10,$59,$0A,$86,$00,$00,$07
    45:05.419: (45:05.419)$40,$55,$6B
    45:05.435: (45:05.422)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:05.579: (45:05.563)$F0,$56,$F1,$C9
    45:05.611: (45:05.595)$10,$59,$0A,$86,$00,$00,$07
    45:05.627: (45:05.627)$40,$55,$6B
    45:05.659: (45:05.643)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:05.803: (45:05.803)$10,$59,$0A,$86,$00,$00,$07
    45:05.835: (45:05.835)$40,$55,$6B
    45:05.851: (45:05.838)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:06.011: (45:05.995)$10,$59,$0A,$86,$00,$00,$07
    45:06.027: (45:06.027)$40,$55,$6B
    45:06.059: (45:06.043)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:06.203: (45:06.203)$10,$59,$0A,$86,$00,$00,$07
    45:06.235: (45:06.235)$40,$55,$6B
    45:06.251: (45:06.238)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:06.411: (45:06.395)$10,$59,$0A,$86,$00,$00,$07
    45:06.427: (45:06.427)$40,$55,$6B
    45:06.459: (45:06.430)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:06.587: (45:06.587)$F0,$56,$F1,$C9
    45:06.619: (45:06.603)$10,$59,$0A,$86,$00,$00,$07
    45:06.635: (45:06.635)$40,$55,$6B
    45:06.667: (45:06.651)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:06.811: (45:06.811)$10,$59,$0A,$86,$00,$00,$07
    45:06.843: (45:06.843)$40,$55,$6B
    45:06.859: (45:06.846)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:07.019: (45:07.003)$10,$59,$0A,$86,$00,$00,$07
    45:07.035: (45:07.035)$40,$55,$6B
    45:07.067: (45:07.051)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:07.212: (45:07.212)$10,$59,$0A,$86,$00,$00,$07
    45:07.244: (45:07.244)$40,$55,$6B
    45:07.260: (45:07.246)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:07.420: (45:07.403)$10,$59,$0A,$86,$00,$00,$07
    45:07.436: (45:07.436)$40,$55,$6B
    45:07.468: (45:07.451)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:07.596: (45:07.595)$F0,$56,$F1,$C9
    45:07.628: (45:07.628)$10,$59,$0A,$86,$00,$00,$07
    45:07.660: (45:07.644)$40,$55,$6B
    45:07.676: (45:07.662)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:07.820: (45:07.820)$10,$59,$0A,$86,$00,$00,$07
    45:07.852: (45:07.852)$40,$55,$6B
    45:07.868: (45:07.854)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:08.028: (45:08.012)$10,$59,$0A,$86,$00,$00,$07
    45:08.060: (45:08.044)$40,$55,$6B
    45:08.076: (45:08.062)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:08.220: (45:08.220)$10,$59,$0A,$86,$00,$00,$07
    45:08.252: (45:08.252)$40,$55,$6B
    45:08.268: (45:08.255)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:08.428: (45:08.412)$10,$59,$0A,$86,$00,$00,$07
    45:08.460: (45:08.444)$40,$55,$6B
    45:08.476: (45:08.463)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:08.604: (45:08.604)$F0,$56,$F1,$C9
    45:08.636: (45:08.636)$10,$59,$0A,$86,$00,$00,$07
    45:08.668: (45:08.652)$40,$55,$6B
    45:08.684: (45:08.671)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:08.844: (45:08.828)$10,$59,$0A,$86,$00,$00,$07
    45:08.860: (45:08.860)$40,$55,$6B
    45:08.876: (45:08.863)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:09.036: (45:09.036)$10,$59,$0A,$86,$00,$00,$07
    45:09.068: (45:09.052)$40,$55,$6B
    45:09.084: (45:09.071)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:09.244: (45:09.228)$10,$59,$0A,$86,$00,$00,$07
    45:09.260: (45:09.260)$40,$55,$6B
    45:09.276: (45:09.263)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:09.436: (45:09.436)$10,$59,$0A,$86,$00,$00,$07
    45:09.468: (45:09.452)$40,$55,$6B
    45:09.484: (45:09.471)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:09.612: (45:09.612)$F0,$56,$F1,$C9
    45:09.644: (45:09.644)$10,$59,$0A,$86,$00,$00,$07
    45:09.676: (45:09.676)$40,$55,$6B
    45:09.692: (45:09.679)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:09.852: (45:09.836)$10,$59,$0A,$86,$00,$00,$07
    45:09.868: (45:09.868)$40,$55,$6B
    45:09.884: (45:09.871)$41,$61,$00,$20,$00,$86,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$46
    45:10.044: (45:10.044)$10,$59,$0A,$86,$00,$00,$07
    45:10.076: (45:10.076)$40,$55,$6B
    45:10.092: (45:10.079)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:10.252: (45:10.237)$10,$59,$0A,$86,$00,$00,$07
    45:10.269: (45:10.268)$40,$55,$6B
    45:10.284: (45:10.271)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:10.444: (45:10.444)$10,$59,$0A,$87,$00,$00,$06
    45:10.476: (45:10.476)$40,$55,$6B
    45:10.492: (45:10.479)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:10.621: (45:10.621)$F0,$56,$F1,$C9
    45:10.653: (45:10.652)$10,$59,$0A,$87,$00,$00,$06
    45:10.685: (45:10.685)$40,$55,$6B
    45:10.701: (45:10.687)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:10.861: (45:10.844)$10,$59,$0A,$87,$00,$00,$06
    45:10.876: (45:10.876)$40,$55,$6B
    45:10.909: (45:10.879)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:11.053: (45:11.053)$10,$59,$0A,$87,$00,$00,$06
    45:11.085: (45:11.085)$40,$55,$6B
    45:11.101: (45:11.087)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:11.261: (45:11.245)$10,$59,$0A,$87,$00,$00,$06
    45:11.277: (45:11.277)$40,$55,$6B
    45:11.309: (45:11.279)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:11.453: (45:11.453)$10,$59,$0A,$87,$00,$00,$06
    45:11.485: (45:11.485)$40,$55,$6B
    45:11.501: (45:11.488)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:11.629: (45:11.629)$F0,$56,$F1,$C9
    45:11.661: (45:11.661)$10,$59,$0A,$87,$00,$00,$06
    45:11.693: (45:11.693)$40,$55,$6B
    45:11.709: (45:11.695)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:11.869: (45:11.853)$10,$59,$0A,$87,$00,$00,$06
    45:11.885: (45:11.885)$40,$55,$6B
    45:11.917: (45:11.901)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:12.061: (45:12.061)$10,$59,$0A,$87,$00,$00,$06
    45:12.093: (45:12.093)$40,$55,$6B
    45:12.109: (45:12.096)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:12.269: (45:12.253)$10,$59,$0A,$87,$00,$00,$06
    45:12.285: (45:12.285)$40,$55,$6B
    45:12.317: (45:12.301)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:12.461: (45:12.461)$10,$59,$0A,$87,$00,$00,$06
    45:12.493: (45:12.493)$40,$55,$6B
    45:12.509: (45:12.496)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:12.637: (45:12.637)$F0,$56,$F1,$C9
    45:12.669: (45:12.669)$10,$59,$0A,$87,$00,$00,$06
    45:12.701: (45:12.701)$40,$55,$6B
    45:12.717: (45:12.704)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:12.877: (45:12.861)$10,$59,$0A,$87,$00,$00,$06
    45:12.909: (45:12.893)$40,$55,$6B
    45:12.925: (45:12.912)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:13.069: (45:13.069)$10,$59,$0A,$87,$00,$00,$06
    45:13.101: (45:13.101)$40,$55,$6B
    45:13.117: (45:13.104)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:13.277: (45:13.261)$10,$59,$0A,$87,$00,$00,$06
    45:13.293: (45:13.293)$40,$55,$6B
    45:13.325: (45:13.309)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:13.469: (45:13.469)$10,$59,$0A,$87,$00,$00,$06
    45:13.501: (45:13.501)$40,$55,$6B
    45:13.517: (45:13.504)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:13.646: (45:13.646)$F0,$56,$F1,$C9
    45:13.694: (45:13.678)$10,$59,$0A,$87,$00,$00,$06
    45:13.710: (45:13.710)$40,$55,$6B
    45:13.726: (45:13.712)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:13.886: (45:13.886)$10,$59,$0A,$87,$00,$00,$06
    45:13.918: (45:13.902)$40,$55,$6B
    45:13.934: (45:13.920)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:14.094: (45:14.078)$10,$59,$0A,$87,$00,$00,$06
    45:14.110: (45:14.110)$40,$55,$6B
    45:14.126: (45:14.112)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:14.286: (45:14.286)$10,$59,$0A,$87,$00,$00,$06
    45:14.318: (45:14.302)$40,$55,$6B
    45:14.334: (45:14.320)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:14.478: (45:14.478)$10,$59,$0A,$87,$00,$00,$06
    45:14.510: (45:14.510)$40,$55,$6B
    45:14.526: (45:14.513)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:14.670: (45:14.654)$F0,$56,$F1,$C9
    45:14.702: (45:14.686)$10,$59,$0A,$87,$00,$00,$06
    45:14.718: (45:14.718)$40,$55,$6B
    45:14.734: (45:14.721)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:14.894: (45:14.894)$10,$59,$0A,$87,$00,$00,$06
    45:14.926: (45:14.926)$40,$55,$6B
    45:14.942: (45:14.929)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:15.102: (45:15.086)$10,$59,$0A,$87,$00,$00,$06
    45:15.118: (45:15.118)$40,$55,$6B
    45:15.134: (45:15.121)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:15.294: (45:15.294)$10,$59,$0A,$87,$00,$00,$06
    45:15.326: (45:15.326)$40,$55,$6B
    45:15.342: (45:15.329)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:15.502: (45:15.486)$10,$59,$0A,$87,$00,$00,$06
    45:15.518: (45:15.518)$40,$55,$6B
    45:15.534: (45:15.521)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:15.678: (45:15.662)$F0,$56,$F1,$C9
    45:15.710: (45:15.694)$10,$59,$0A,$87,$00,$00,$06
    45:15.726: (45:15.726)$40,$55,$6B
    45:15.758: (45:15.730)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:15.902: (45:15.902)$10,$59,$0A,$87,$00,$00,$06
    45:15.934: (45:15.934)$40,$55,$6B
    45:15.950: (45:15.937)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:16.110: (45:16.094)$10,$59,$0A,$87,$00,$00,$06
    45:16.126: (45:16.126)$40,$55,$6B
    45:16.158: (45:16.129)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:16.302: (45:16.302)$10,$59,$0A,$87,$00,$00,$06
    45:16.334: (45:16.334)$40,$55,$6B
    45:16.350: (45:16.337)$41,$61,$00,$20,$00,$87,$7E,$01,$00,$00 ,$00,$7A,$00,$79,$45
    45:16.510: (45:16.495)$10,$59,$0A,$87,$00,$00,$06
    45:16.527: (45:16.527)$40,$55,$6B
    45:16.559: (45:16.529)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:16.687: (45:16.671)$F0,$56,$F1,$C9
    45:16.719: (45:16.703)$10,$59,$0A,$87,$00,$00,$06
    45:16.734: (45:16.734)$40,$55,$6B
    45:16.767: (45:16.751)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:16.911: (45:16.910)$10,$59,$0A,$87,$00,$00,$06
    45:16.943: (45:16.942)$40,$55,$6B
    45:16.959: (45:16.945)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:17.118: (45:17.102)$10,$59,$0A,$87,$00,$00,$06
    45:17.135: (45:17.135)$40,$55,$6B
    45:17.167: (45:17.151)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:17.311: (45:17.311)$10,$59,$0A,$87,$00,$00,$06
    45:17.343: (45:17.343)$40,$55,$6B
    45:17.359: (45:17.345)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:17.519: (45:17.503)$10,$59,$0A,$87,$00,$00,$06
    45:17.535: (45:17.535)$40,$55,$6B
    45:17.567: (45:17.551)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:17.695: (45:17.695)$F0,$56,$F1,$C9
    45:17.727: (45:17.711)$10,$59,$0A,$87,$00,$00,$06
    45:17.743: (45:17.743)$40,$55,$6B
    45:17.775: (45:17.759)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:17.919: (45:17.919)$10,$59,$0A,$87,$00,$00,$06
    45:17.951: (45:17.951)$40,$55,$6B
    45:17.967: (45:17.954)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:18.127: (45:18.111)$10,$59,$0A,$87,$00,$00,$06
    45:18.143: (45:18.143)$40,$55,$6B
    45:18.175: (45:18.159)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:18.319: (45:18.319)$10,$59,$0A,$87,$00,$00,$06
    45:18.351: (45:18.351)$40,$55,$6B
    45:18.367: (45:18.353)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:18.527: (45:18.511)$10,$59,$0A,$87,$00,$00,$06
    45:18.543: (45:18.543)$40,$55,$6B
    45:18.575: (45:18.559)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:18.703: (45:18.703)$F0,$56,$F1,$C9
    45:18.735: (45:18.735)$10,$59,$0A,$87,$00,$00,$06
    45:18.767: (45:18.751)$40,$55,$6B
    45:18.783: (45:18.770)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:18.943: (45:18.927)$10,$59,$0A,$87,$00,$00,$06
    45:18.959: (45:18.959)$40,$55,$6B
    45:18.975: (45:18.962)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:19.135: (45:19.135)$10,$59,$0A,$87,$00,$00,$06
    45:19.167: (45:19.151)$40,$55,$6B
    45:19.183: (45:19.170)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:19.327: (45:19.327)$10,$59,$0A,$87,$00,$00,$06
    45:19.359: (45:19.359)$40,$55,$6B
    45:19.376: (45:19.362)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:19.536: (45:19.535)$10,$59,$0A,$87,$00,$00,$06
    45:19.567: (45:19.551)$40,$55,$6B
    45:19.584: (45:19.572)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:19.712: (45:19.712)$F0,$56,$F1,$C9
    45:19.743: (45:19.743)$10,$59,$0A,$87,$00,$00,$06
    45:19.776: (45:19.775)$40,$55,$6B
    45:19.791: (45:19.778)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:19.952: (45:19.936)$10,$59,$0A,$87,$00,$00,$06
    45:19.968: (45:19.968)$40,$55,$6B
    45:19.984: (45:19.970)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
    45:20.144: (45:20.144)$10,$59,$0A,$87,$00,$00,$06
    45:20.176: (45:20.176)$40,$55,$6B
    45:20.192: (45:20.182)$41,$61,$00,$20,$00,$87,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$44
  9. #19
    Jan 2013
    And here's Corvette_Camaro_90_91
    45:50.469: Opening COM2 8228,8,N,1
    46:03.595: Scan for chatter...
    46:03.595: Waiting for Aldl bus silence of at least 100ms...
    46:03.775: (46:03.759)$10,$59,$0A,$86,$00,$00,$07
    46:03.791: (46:03.791)$40,$55,$6B
    46:03.807: (46:03.794)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:03.967: (46:03.967)$10,$59,$0A,$86,$00,$00,$07
    46:03.999: (46:03.983)$40,$55,$6B
    46:04.015: (46:04.001)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:04.143: (46:04.143)$F0,$56,$F1,$C9
    46:04.175: (46:04.175)$10,$59,$0A,$86,$00,$00,$07
    46:04.207: (46:04.207)$40,$55,$6B
    46:04.223: (46:04.209)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:04.383: (46:04.367)$10,$59,$0A,$86,$00,$00,$07
    46:04.399: (46:04.399)$40,$55,$6B
    46:04.415: (46:04.402)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:04.575: (46:04.575)$10,$59,$0A,$86,$00,$00,$07
    46:04.607: (46:04.607)$40,$55,$6B
    46:04.623: (46:04.610)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:04.783: (46:04.767)$10,$59,$0A,$86,$00,$00,$07
    46:04.799: (46:04.799)$40,$55,$6B
    46:04.815: (46:04.802)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:04.975: (46:04.975)$10,$59,$0A,$86,$00,$00,$07
    46:05.007: (46:05.007)$40,$55,$6B
    46:05.023: (46:05.010)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:05.151: (46:05.151)$F0,$56,$F1,$C9
    46:05.183: (46:05.183)$10,$59,$0A,$86,$00,$00,$07
    46:05.215: (46:05.215)$40,$55,$6B
    46:05.231: (46:05.218)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:05.391: (46:05.375)$10,$59,$0A,$86,$00,$00,$07
    46:05.407: (46:05.407)$40,$55,$6B
    46:05.439: (46:05.410)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:05.583: (46:05.583)$10,$59,$0A,$86,$00,$00,$07
    46:05.615: (46:05.615)$40,$55,$6B
    46:05.631: (46:05.618)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:05.792: (46:05.775)$10,$59,$0A,$86,$00,$00,$07
    46:05.808: (46:05.808)$40,$55,$6B
    46:05.839: (46:05.810)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:05.984: (46:05.984)$10,$59,$0A,$86,$00,$00,$07
    46:06.016: (46:06.016)$40,$55,$6B
    46:06.032: (46:06.018)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:06.160: (46:06.160)$F0,$56,$F1,$C9
    46:06.192: (46:06.192)$10,$59,$0A,$86,$00,$00,$07
    46:06.224: (46:06.224)$40,$55,$6B
    46:06.240: (46:06.226)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:06.400: (46:06.384)$10,$59,$0A,$86,$00,$00,$07
    46:06.416: (46:06.416)$40,$55,$6B
    46:06.448: (46:06.432)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:06.592: (46:06.592)$10,$59,$0A,$86,$00,$00,$07
    46:06.624: (46:06.624)$40,$55,$6B
    46:06.640: (46:06.627)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:06.800: (46:06.784)$10,$59,$0A,$86,$00,$00,$07
    46:06.816: (46:06.816)$40,$55,$6B
    46:06.848: (46:06.832)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:06.992: (46:06.992)$10,$59,$0A,$86,$00,$00,$07
    46:07.024: (46:07.024)$40,$55,$6B
    46:07.040: (46:07.027)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:07.168: (46:07.168)$F0,$56,$F1,$C9
    46:07.200: (46:07.200)$10,$59,$0A,$86,$00,$00,$07
    46:07.232: (46:07.232)$40,$55,$6B
    46:07.248: (46:07.235)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:07.408: (46:07.392)$10,$59,$0A,$86,$00,$00,$07
    46:07.440: (46:07.424)$40,$55,$6B
    46:07.456: (46:07.443)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:07.600: (46:07.600)$10,$59,$0A,$86,$00,$00,$07
    46:07.633: (46:07.632)$40,$55,$6B
    46:07.648: (46:07.635)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:07.808: (46:07.792)$10,$59,$0A,$86,$00,$00,$07
    46:07.825: (46:07.824)$40,$55,$6B
    46:07.856: (46:07.840)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:08.001: (46:08.001)$10,$59,$0A,$86,$00,$00,$07
    46:08.033: (46:08.033)$40,$55,$6B
    46:08.049: (46:08.035)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:08.177: (46:08.177)$F0,$56,$F1,$C9
    46:08.225: (46:08.209)$10,$59,$0A,$86,$00,$00,$07
    46:08.241: (46:08.241)$40,$55,$6B
    46:08.257: (46:08.243)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:08.417: (46:08.417)$10,$59,$0A,$86,$00,$00,$07
    46:08.449: (46:08.433)$40,$55,$6B
    46:08.465: (46:08.451)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:08.625: (46:08.609)$10,$59,$0A,$86,$00,$00,$07
    46:08.641: (46:08.641)$40,$55,$6B
    46:08.657: (46:08.643)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:08.817: (46:08.817)$10,$59,$0A,$86,$00,$00,$07
    46:08.849: (46:08.833)$40,$55,$6B
    46:08.865: (46:08.851)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:09.025: (46:09.009)$10,$59,$0A,$86,$00,$00,$07
    46:09.041: (46:09.041)$40,$55,$6B
    46:09.057: (46:09.043)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:09.201: (46:09.185)$F0,$56,$F1,$C9
    46:09.233: (46:09.217)$10,$59,$0A,$86,$00,$00,$07
    46:09.249: (46:09.249)$40,$55,$6B
    46:09.265: (46:09.252)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:09.425: (46:09.425)$10,$59,$0A,$86,$00,$00,$07
    46:09.457: (46:09.457)$40,$55,$6B
    46:09.473: (46:09.460)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:09.633: (46:09.617)$10,$59,$0A,$86,$00,$00,$07
    46:09.649: (46:09.649)$40,$55,$6B
    46:09.665: (46:09.652)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:09.825: (46:09.825)$10,$59,$0A,$86,$00,$00,$07
    46:09.857: (46:09.857)$40,$55,$6B
    46:09.873: (46:09.860)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:10.033: (46:10.017)$10,$59,$0A,$86,$00,$00,$07
    46:10.049: (46:10.049)$40,$55,$6B
    46:10.065: (46:10.055)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:10.209: (46:10.193)$F0,$56,$F1,$C9
    46:10.241: (46:10.225)$10,$59,$0A,$86,$00,$00,$07
    46:10.257: (46:10.257)$40,$55,$6B
    46:10.289: (46:10.260)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:10.434: (46:10.434)$10,$59,$0A,$86,$00,$00,$07
    46:10.466: (46:10.466)$40,$55,$6B
    46:10.482: (46:10.468)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:10.642: (46:10.626)$10,$59,$0A,$86,$00,$00,$07
    46:10.658: (46:10.658)$40,$55,$6B
    46:10.674: (46:10.660)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:10.834: (46:10.834)$10,$59,$0A,$86,$00,$00,$07
    46:10.866: (46:10.866)$40,$55,$6B
    46:10.882: (46:10.868)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:11.042: (46:11.026)$10,$59,$0A,$86,$00,$00,$07
    46:11.058: (46:11.058)$40,$55,$6B
    46:11.074: (46:11.060)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:11.218: (46:11.202)$F0,$56,$F1,$C9
    46:11.250: (46:11.234)$10,$59,$0A,$86,$00,$00,$07
    46:11.266: (46:11.266)$40,$55,$6B
    46:11.298: (46:11.282)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:11.442: (46:11.442)$10,$59,$0A,$86,$00,$00,$07
    46:11.474: (46:11.474)$40,$55,$6B
    46:11.490: (46:11.477)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:11.650: (46:11.634)$10,$59,$0A,$86,$00,$00,$07
    46:11.666: (46:11.666)$40,$55,$6B
    46:11.698: (46:11.682)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:11.842: (46:11.842)$10,$59,$0A,$86,$00,$00,$07
    46:11.874: (46:11.874)$40,$55,$6B
    46:11.890: (46:11.877)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:12.050: (46:12.034)$10,$59,$0A,$86,$00,$00,$07
    46:12.066: (46:12.066)$40,$55,$6B
    46:12.098: (46:12.082)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:12.226: (46:12.226)$F0,$56,$F1,$C9
    46:12.258: (46:12.242)$10,$59,$0A,$86,$00,$00,$07
    46:12.274: (46:12.274)$40,$55,$6B
    46:12.306: (46:12.290)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:12.450: (46:12.450)$10,$59,$0A,$86,$00,$00,$07
    46:12.482: (46:12.482)$40,$55,$6B
    46:12.498: (46:12.485)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:12.658: (46:12.642)$10,$59,$0A,$86,$00,$00,$07
    46:12.674: (46:12.674)$40,$55,$6B
    46:12.706: (46:12.690)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:12.850: (46:12.850)$10,$59,$0A,$86,$00,$00,$07
    46:12.882: (46:12.882)$40,$55,$6B
    46:12.898: (46:12.885)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:13.058: (46:13.042)$10,$59,$0A,$86,$00,$00,$07
    46:13.074: (46:13.074)$40,$55,$6B
    46:13.106: (46:13.090)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:13.234: (46:13.234)$F0,$56,$F1,$C9
    46:13.266: (46:13.266)$10,$59,$0A,$86,$00,$00,$07
    46:13.298: (46:13.282)$40,$55,$6B
    46:13.314: (46:13.301)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:13.459: (46:13.459)$10,$59,$0A,$86,$00,$00,$07
    46:13.490: (46:13.490)$40,$55,$6B
    46:13.507: (46:13.493)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:13.667: (46:13.667)$10,$59,$0A,$86,$00,$00,$07
    46:13.699: (46:13.683)$40,$55,$6B
    46:13.715: (46:13.701)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:13.859: (46:13.859)$10,$59,$0A,$86,$00,$00,$07
    46:13.891: (46:13.891)$40,$55,$6B
    46:13.907: (46:13.893)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:14.067: (46:14.051)$10,$59,$0A,$86,$00,$00,$07
    46:14.099: (46:14.083)$40,$55,$6B
    46:14.115: (46:14.101)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:14.243: (46:14.243)$F0,$56,$F1,$C9
    46:14.275: (46:14.275)$10,$59,$0A,$86,$00,$00,$07
    46:14.307: (46:14.291)$40,$55,$6B
    46:14.323: (46:14.309)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:14.483: (46:14.467)$10,$59,$0A,$86,$00,$00,$07
    46:14.499: (46:14.499)$40,$55,$6B
    46:14.515: (46:14.502)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:14.675: (46:14.675)$10,$59,$0A,$86,$00,$00,$07
    46:14.707: (46:14.691)$40,$55,$6B
    46:14.723: (46:14.710)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:14.883: (46:14.867)$10,$59,$0A,$86,$00,$00,$07
    46:14.899: (46:14.899)$40,$55,$6B
    46:14.915: (46:14.902)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:15.075: (46:15.075)$10,$59,$0A,$86,$00,$00,$07
    46:15.107: (46:15.091)$40,$55,$6B
    46:15.123: (46:15.110)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:15.251: (46:15.251)$F0,$56,$F1,$C9
    46:15.283: (46:15.283)$10,$59,$0A,$86,$00,$00,$07
    46:15.315: (46:15.315)$40,$55,$6B
    46:15.331: (46:15.318)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:15.491: (46:15.475)$10,$59,$0A,$86,$00,$00,$07
    46:15.507: (46:15.507)$40,$55,$6B
    46:15.523: (46:15.510)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:15.683: (46:15.683)$10,$59,$0A,$86,$00,$00,$07
    46:15.715: (46:15.715)$40,$55,$6B
    46:15.731: (46:15.718)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:15.891: (46:15.875)$10,$59,$0A,$86,$00,$00,$07
    46:15.907: (46:15.907)$40,$55,$6B
    46:15.923: (46:15.910)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:16.083: (46:16.083)$10,$59,$0A,$86,$00,$00,$07
    46:16.115: (46:16.115)$40,$55,$6B
    46:16.131: (46:16.118)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:16.259: (46:16.259)$F0,$56,$F1,$C9
    46:16.291: (46:16.291)$10,$59,$0A,$86,$00,$00,$07
    46:16.323: (46:16.323)$40,$55,$6B
    46:16.340: (46:16.326)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:16.499: (46:16.483)$10,$59,$0A,$86,$00,$00,$07
    46:16.515: (46:16.515)$40,$55,$6B
    46:16.547: (46:16.531)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:16.692: (46:16.692)$10,$59,$0A,$86,$00,$00,$07
    46:16.724: (46:16.724)$40,$55,$6B
    46:16.740: (46:16.726)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:16.900: (46:16.884)$10,$59,$0A,$86,$00,$00,$07
    46:16.916: (46:16.916)$40,$55,$6B
    46:16.948: (46:16.918)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:17.092: (46:17.092)$10,$59,$0A,$86,$00,$00,$07
    46:17.124: (46:17.124)$40,$55,$6B
    46:17.140: (46:17.126)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:17.268: (46:17.268)$F0,$56,$F1,$C9
    46:17.300: (46:17.300)$10,$59,$0A,$86,$00,$00,$07
    46:17.332: (46:17.332)$40,$55,$6B
    46:17.348: (46:17.334)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:17.508: (46:17.492)$10,$59,$0A,$86,$00,$00,$07
    46:17.524: (46:17.524)$40,$55,$6B
    46:17.556: (46:17.540)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:17.700: (46:17.700)$10,$59,$0A,$86,$00,$00,$07
    46:17.732: (46:17.732)$40,$55,$6B
    46:17.748: (46:17.735)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:17.908: (46:17.892)$10,$59,$0A,$86,$00,$00,$07
    46:17.924: (46:17.924)$40,$55,$6B
    46:17.956: (46:17.940)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:18.100: (46:18.100)$10,$59,$0A,$86,$00,$00,$07
    46:18.132: (46:18.132)$40,$55,$6B
    46:18.148: (46:18.135)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:18.276: (46:18.276)$F0,$56,$F1,$C9
    46:18.308: (46:18.308)$10,$59,$0A,$86,$00,$00,$07
    46:18.340: (46:18.340)$40,$55,$6B
    46:18.356: (46:18.343)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:18.516: (46:18.500)$10,$59,$0A,$86,$00,$00,$07
    46:18.548: (46:18.532)$40,$55,$6B
    46:18.564: (46:18.551)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:18.708: (46:18.708)$10,$59,$0A,$86,$00,$00,$07
    46:18.740: (46:18.740)$40,$55,$6B
    46:18.756: (46:18.743)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:18.917: (46:18.901)$10,$59,$0A,$86,$00,$00,$07
    46:18.933: (46:18.933)$40,$55,$6B
    46:18.965: (46:18.949)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:19.109: (46:19.109)$10,$59,$0A,$86,$00,$00,$07
    46:19.141: (46:19.141)$40,$55,$6B
    46:19.157: (46:19.143)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:19.285: (46:19.285)$F0,$56,$F1,$C9
    46:19.333: (46:19.317)$10,$59,$0A,$86,$00,$00,$07
    46:19.349: (46:19.349)$40,$55,$6B
    46:19.365: (46:19.351)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:19.525: (46:19.525)$10,$59,$0A,$86,$00,$00,$07
    46:19.557: (46:19.541)$40,$55,$6B
    46:19.573: (46:19.559)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:19.733: (46:19.717)$10,$59,$0A,$86,$00,$00,$07
    46:19.749: (46:19.749)$40,$55,$6B
    46:19.765: (46:19.752)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:19.925: (46:19.925)$10,$59,$0A,$86,$00,$00,$07
    46:19.957: (46:19.941)$40,$55,$6B
    46:19.973: (46:19.960)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:20.133: (46:20.117)$10,$59,$0A,$86,$00,$00,$07
    46:20.149: (46:20.149)$40,$55,$6B
    46:20.165: (46:20.151)$41,$61,$00,$20,$00,$86,$7F,$01,$00,$00 ,$00,$7A,$00,$79,$45
    46:20.309: (46:20.293)$F0,$56,$F1,$C9
  10. #20
    Ok that makes it clearer, thanks for the info.
    Looking at the chatter its really just 4 items that repeat at different intervals:
    The first byte identifies the module involved in the message:
    $10 is the body controller
    $40/$41 is the engine controller
    $F0 is the heartbeat message to the scan tool
    So I recommend using $F0,$56,$F1,$C9 as the heartbeat message.
    Looking over the trace the heartbeat has about 32 ms before the next message (the $40 message) is transmitted.
    That means once EFILive sees the $F0 message it has to start transmitting within 32 ms to "own" the bus, preferably sooner.
    So I recommend the following timing settings:
    T1 = 10
    T2 = 0
    T3 = 150
    T4 = 10
    T5 = 0
    T6 = 15
    I would leave the "Max232 echo" checked as I think that your cable does echo.
    If you keep getting "echo not found" errors (with no other errors), then uncheck it
    If you're getting checksum errors, frame truncation errors etc, then those errors will be causing the "echo not found" error.
    The heartbeat and timings I suggested should clear up the checksum and frame truncation errors.
    If you send me:
    1. the 8th letter/digit of your VIN
    2. The engine RPO (like LT1 or LT5)
    3. The engine size in liters (like 5.0)
    4. The year of manufacture
    then I can hopefully track down exactly which vehicle definition you should be using.
  1. Corisca and communicating with ALDL
    By tunethis in forum EFILive V4
    Last Post: December 20th, 2012, 11:31 AM
  2. Trouble Communicating with E38 ECM
    By philip.long in forum E37, E38 & E67 PFI ECM's
    Last Post: January 25th, 2009, 09:33 AM
  3. FS not communicating in dead poll
    By Big Block in forum Black Box Logging
    Last Post: January 7th, 2008, 12:24 PM
  4. Having trouble communicating with 07tbss
    By Stoichiometric in forum E37, E38 & E67 PFI ECM's
    Last Post: October 12th, 2007, 07:57 PM
