Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 76
Thread: EFILive Pre-Release 05
    No problem, I also encountered the same thing as Simon with the log zoomed all the way out (scrollbar docks to the left side even though it should just be across the entire window).
    Unfortunately without maps, kinda hard to use for test/tuning still. Ill try it out tomorrow on my way to work, stoked that this means both ECM and TCMs can be logged at once (via pass-thru)!
    Pass-thru logging is not available yet. The pre-release software is only capable of loading/displaying/editing log files at the moment.
    But yes, once I activate pass-thru then you can log both ECM and TCM together, (although you can do that now using BBL).
    When attempting to "Zoom Selected" (cntrl - alt - s) it seems to actually perform a "Zoom None"
    Yes, that's broken - will be fixed asap.
    When zooming all the way out, the scroll bar at the bottom sits on the left hand side, even if there is no additional frames to display. This makes it look like you can move the scroll bar to the right, but there's nothing to move to. When all available frames are displayed, the scroll bar should occupy the entire "scroll" widget so as to indicate all frames are currently displayed.
    Yes, that's broken too - will be fixed asap.
    When selecting PID's for charts in the V8 Scan Tool, the list of available PIDs is incomplete. The PID's appear in alphabetical order, but only go as far as "EXT" prefixed PIDs. I cannot select PIDs such as "GM.KNKRET" as it's not listed. If I change to a different controller log, I see TCM PID's but not all of them, so I think it's a PID count issue.
    Do you mean the PIDs listed in the green section or the yellow section? If you mean green, then those PIDs come from the log file, in which case could you please send me the log files so I can see the problem for myself.
    It's blindingly fast though. The 46MB E39 file took 8 seconds to plot!
    I have been working hard on the code optimization - I even had to learn OpenGL to implement the hardware acceleration
    The Tune Tool maps are also developed using OpenGL 3D hardware acceleration, they are also crisp and fast - here's what they look like in the V8 tune tool.
    Quote Originally Posted by BlackCPG View Post
    When a custom dashboard is re-loaded, the custom PID text is not. The default name(s) are loaded.
    I can't reproduce this problem, can you list the exact steps that you took that show this problem?
    When right clicking and selecting a PID, the error below is shown. Win XP SP3 (Win7 ok)
    This happened twice, and has not happened since.
    Attachment 14463
    Also have a similar error when attempting to edit a note. Both XP and Win7.
    Again I can't reproduce this. If you can reproduce it again, the exact step required to reproduce will allow me to track it down.
    Odd data in save as dialog. Win XP SP3 (Win7 ok)
    Attachment 14465
    I can reproduce this problem on WinXP, it is on the list to be fixed.
    Really like the new look and feel, and wow is it fast!
    Jan 2013
    I am having a problem with the V2 handheld since the firmware and V8 update, when using the hot key F1 which I have set to LS1B I get error code $0185 file or folder not found. I programmed it with V8 under the BBX button. I switched the F1 hotkey to E35A and it loads.
    UPDATE: I moved the LS1B to F3 and it won't read there either. Are my LS1B files corrupt? I have tried reformatting the config file and reprogramming with the BBX button in V8. How can I get good LS1B files for the BBX?
    Thanks,
    Branden
    Jul 2007
    Hmm.... I was trying to chart GM.KNKRET, but couldn't find it. Now I can.
    It may have been an issue with dual monitors, as previously I was working on the second monitor. I can't remember seeing the little "scroll up / down" arrows on the chart PID list before, but maybe the bigger monitor didn't need them? I'll try a different monitor later to see if it acts the same.
    Simon.
    Quote Originally Posted by bmc1025 View Post
    Thanks,
    Branden
    In V8 under BBx, did you do Program All (accessible via downarrow next to Program)...?
    Dec 2006
    downloaded and installed
  9. #19
    Oct 2011
    - Select E54 -> Select "DMAX_TRQ_M","FUEL_MAIN_M","RPM" -> Charts(F4) -> Right click and select PID's -> Config - Edit Dashboard-> Select PID's on dashboard and change the caption name to "Torque", "Fuel", "RPM" -> OK -> Save Dashboard As -> Save as "test.dsh" > Close V8 -> Re-open V8 -> Scan Tool -> Open dashboard -> test.dsh -> PID's did not retain the custom caption text, they say DMAX_TRQ_M ect.
    This does the same thing for other controllers and PID's as well.
    Attachment 14463
    This did it today in Win7 as well.
    It is hit and miss. When it does it, Charts(F4) -> Right click -> Select PID -> Access violation error
    Also, Open log file -> log1.efi -> Right click - options - notes - add note -> hover the note and right click -> options - notes - edit note -> Access violation error.
    03 6spd
  10. #20
    May 2012
    Does this pre-release fix the 6.7 Cummins overhead and dinging issues?
    Tobin
    2006 Ram 2500 5.9 Cummins 48RE
    2008 6.7 Cummins swap in 1997 Ford F250 + 4R100 with PCS Control
  1. EFILive 7.3 pre-release software is now available
    Last Post: August 18th, 2005, 10:51 PM
