Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 76
Thread: EFILive Pre-Release 05
  1. #21
    Jul 2007
    OK, tried a little more testing on the chart PID lists. This morning, I no longer get the "up/down" arrows on the PID list...
    The actual PID count is as follows...
    Code:
    Source Metadata as follows...
            [FILE],2
            VERSION=7.1
            DECSEP=.
            [VEHICLE],2
            VIN=6G1ZK54H26LXXXXXX
            OS=12607218
            [PID],31
            CALC.BEN1_E38=0
            SAE.AAT=0
            SAE.IAT=1
            SAE.SPARKADV=2
            SAE.MAP=3
            SAE.VSS=4
            GM.ETCTP=5
            E38.INVLVTMP_M=7
            E38.AFRATIO_M=9
            SAE.SHRTFT1=11
            SAE.LONGFT1=12
            SAE.SHRTFT2=13
            SAE.LONGFT2=14
            GM.INJPWB1=15
            GM.INJPWB2=17
            SAE.ECT=19
            GM.KNKRET=20
            E38.OCTSCL_M=21
            GM.MAFFREQ2=23
            GM.AIRPERSEC=25
            E38.APCYL_M=27
            SAE.RPM=29
            GM.HO2S11=31
            GM.HO2S21=32
            GM.BRKR=33
            GM.ENGOILP=34
            GM.APP=35
            GM.VOLTS=37
            GM.TRACTRQ=38
            SAE.LOAD_PCT=39
            SAE.EQ_RAT=40
            [DTC],1
            COUNT=0
            [DATA],6
            DASHBOARD=
            PIDCOUNT=31
            CHANNELCOUNT=42
            FRAMECOUNT=00036516
            STARTDATE=2456325
            STARTTIME=136092
            [End_Of_Meta_Data],0
    Channel Count: 42
    Frame size: 50
    Data length: 1825500
    I'll see if I can reproduce.
    Simon.
  2. #22
    Jul 2007
    With the Dashboard list, it appears that either...
    1. The program is not reading the current list of dash page files.
    2. There is no way of specifying a "non-default" directory to store the dash page files in.
    In V7.5 Scan tool, you could change the default directories by either the edit > properties > folder dialogue, or by editing the registry keys. In V8 I see no options to change the default directories. I've saved a new dash page ( in a non standard directory ) and while the two std. dash pages are listed in the drop down box, the new one is not.
    Also, when opening a new dash file via the menu or <cntrl> - <shift> - O, the initial directory defaults to the last used, whether the last used was for a dash page, or opening a log file. IE. If you open a log file off the SD card (B:/EFILive/Scan/*.efi) then go to open a dash page, the window defaults back to B:/EFILive/Scan. It'd be good if each "File Open" option kept track of its own "last used" or at least defaulted to the required directory.
    Just noticed that once you open a custom dash page, the option appears in the drop down list....
  3. #23
    Quote Originally Posted by Tobin View Post
    Does this pre-release fix the 6.7 Cummins overhead and dinging issues?
    Tobin
    No sorry it does not, that is still being worked on amongst our beta testers.
  4. #24
    Quote Originally Posted by swingtan View Post
    It should also add it to the list when you save it. I will fix that.
  5. #25
    Aug 2008
    For what ever reason I cannot seem to copy\paste pids from V7 to V8
  6. #26
    Quote Originally Posted by sreve View Post
    Looks like the V7 "Edit->Copy for Export to V8" option is no longer compatible with the V8 PID lists.
    I'll get it fixed asap.
  7. #27
    Quote Originally Posted by bmc1025 View Post
    I am having a problem with the V2 handheld since the firmware and V8 update, when using the hot key F1 which I have set to LS1B I get error code $0185 file or folder not found. I programmed it with V8 under the BBX button. I switched the F1 hotkey to E35A and it loads.
    UPDATE: I moved the LS1B to F3 and it won't read there either. Are my LS1B files corrupt? I have tried reformatting the config file and reprogramming with the BBX button in V8. How can I get good LS1B files for the BBX?
    Thanks,
    Branden
    Hi Branden, is this still a problem for you, do we need to investigate it further?
  8. #28
    Jan 2013
    I am still having the problem.
    I have tried the following:
    - selected program all in the BBX window in V8
    - formatted config and then program all
    - formatted using the EFILive explorer and then programming all using the BBX window in V8
    I have attached my options.txt file, if you need anything else let me know.
    Thanks,
    Branden
  9. #29
    Thanks,
    Branden
    There is a check-box next to each entry, you must check the check-box for each controller that you want configured/copied to FlashScan.
  10. #30
    Jan 2013
    The box is checked.... It worked before the update, any other suggestions would be appreciated.
    Edit: I wanted to add that it will not work under Scan -> Select PIDs either.
    Thanks,
    Branden
  1. EFILive 7.3 pre-release software is now available
    By Blacky in forum General (Petrol, Gas, Ethanol)
    Last Post: August 18th, 2005, 11:51 PM
