Thanks joecar, I don't suppose you could list all the tables I need to copy over? I'm assuming its pretty much all air, fuel, and timing tables. Also would anyone happen to have stock 1999-2000 ls1 pcm calibration data?
-Shaun
-Shaun
There's too many to list, but you don't necessarily need all of them...
you will need any airmass/ve tables, all the injector tables, spark, idle...
if you open 2 instance of the tunetool (one on the 2000 file, the other on the 2002 file), and just walk thru each folder (take your time over a beer)...
Stock files can be found at www.tunefiledepot.com... they're listed under Stock Tunes (by year, os, car, transmission).
Joe, could he use one of the 99 Camaro files that have been migrated to the 2002 OS? The 99/00 injectors are the same so it should work, just kill VATS/etc, full flash, then start tuning.
Erik,
Yes, he could, but I can't find them anywhere... those would save him lots of time.
Ah, you know what, I just found them (hmmm, funny I couldn't find them before):
F-car 1999 migrated to 2002 M6 (12212156)
F-car 1999 migrated to 2002 A4 (12212156)
Erik, you might want to sanity check my links... my coffee is running low, like this slow cucumber ->
Thanks guys you are all extremely helpful. I really wanted to load up the 2000 camaro tune but also noticed it was from a different OS. Then I saw the 1999 tune with the same OS. I wanted to make sure they were the same but after comparing the two I realized they were not. Here is a quick comparison of the Main VE Tables
2000 Camaro M6 LS1 OS 9381344
LABELS Map kPa {link: SAE.MAP}
RPM {link: SAE.RPM} 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 95 100 105
400 0.847852 0.918945 0.990234 1.083789 1.139258 1.184180 1.218750 1.242578 1.255859 1.365039 1.389453 1.413867 1.438477 1.462891 1.487305 1.524609 1.574805 1.625195 1.625195
800 0.995313 1.066602 1.137695 1.212305 1.267773 1.312891 1.347266 1.371094 1.384570 1.431055 1.455469 1.479883 1.504492 1.528906 1.553320 1.590430 1.640820 1.691211 1.691211
1200 1.051172 1.163477 1.311914 1.343359 1.374805 1.406250 1.437695 1.469336 1.500781 1.467969 1.493750 1.519531 1.545313 1.571094 1.596875 1.660156 1.700781 1.741406 1.741406
1600 1.118359 1.230664 1.391016 1.421484 1.451953 1.482227 1.512695 1.543164 1.573438 1.523047 1.548828 1.574609 1.600391 1.626172 1.651953 1.698047 1.738672 1.779297 1.779297
2000 1.097852 1.210156 1.423828 1.453125 1.482422 1.511719 1.541016 1.570313 1.599609 1.603516 1.629297 1.655078 1.680859 1.706641 1.732422 1.720508 1.761133 1.801758 1.801758
2400 1.018945 1.280859 1.391211 1.469727 1.535156 1.587500 1.626758 1.652734 1.665625 1.671094 1.690234 1.709375 1.728516 1.747656 1.766797 1.784961 1.816797 1.848438 1.848438
2800 1.034180 1.296289 1.430273 1.510156 1.576953 1.630469 1.671094 1.698438 1.712891 1.724023 1.743164 1.762305 1.781445 1.800586 1.819727 1.839648 1.871289 1.902930 1.902930
3200 1.134180 1.558398 1.495508 1.572461 1.637305 1.690039 1.730859 1.759766 1.776563 1.795313 1.813281 1.831055 1.849023 1.866992 1.884961 1.929102 1.963672 1.998438 1.998438
3600 1.175781 1.599805 1.579102 1.655273 1.719336 1.771484 1.811523 1.839648 1.855859 1.874023 1.891992 1.909766 1.927734 1.945703 1.963672 1.999219 2.033789 2.068359 2.068359
4000 1.217188 1.641211 1.662695 1.738086 1.801563 1.852930 1.892188 1.919531 1.934961 1.952734 1.970703 1.988672 2.006445 2.024414 2.042383 2.069141 2.103906 2.138477 2.138477
4400 1.258789 1.682813 1.746289 1.820898 1.883594 1.934180 1.972852 1.999414 2.014063 2.031445 2.049414 2.067383 2.085156 2.103125 2.121094 2.139258 2.173828 2.208398 2.208398
4800 1.300195 1.724219 1.829883 1.903711 1.965625 2.015625 2.053516 2.079297 2.093164 2.110156 2.128125 2.146094 2.163867 2.181836 2.199805 2.209180 2.243945 2.278516 2.278516
5200 1.341602 1.765820 1.913477 1.986719 2.047852 2.097070 2.134180 2.159375 2.172461 2.188867 2.206836 2.224805 2.242578 2.260547 2.278516 2.279297 2.313867 2.348633 2.348633
5600 1.341602 1.765820 1.913477 1.986719 2.047852 2.097070 2.134180 2.159375 2.172461 2.188867 2.206836 2.224805 2.242578 2.260547 2.278516 2.279297 2.313867 2.348633 2.348633
6000 1.341602 1.765820 1.913477 1.986719 2.047852 2.097070 2.134180 2.159375 2.172461 2.188867 2.206836 2.224805 2.242578 2.260547 2.278516 2.279297 2.313867 2.348633 2.348633
6400 1.341602 1.765820 1.913477 1.986719 2.047852 2.097070 2.134180 2.159375 2.172461 2.188867 2.206836 2.224805 2.242578 2.260547 2.278516 2.279297 2.313867 2.348633 2.348633
6800 1.341602 1.765820 1.913477 1.986719 2.047852 2.097070 2.134180 2.159375 2.172461 2.188867 2.206836 2.224805 2.242578 2.260547 2.278516 2.279297 2.313867 2.348633 2.348633
7200 1.341602 1.765820 1.913477 1.986719 2.047852 2.097070 2.134180 2.159375 2.172461 2.188867 2.206836 2.224805 2.242578 2.260547 2.278516 2.279297 2.313867 2.348633 2.348633
7600 1.341602 1.765820 1.913477 1.986719 2.047852 2.097070 2.134180 2.159375 2.172461 2.188867 2.206836 2.224805 2.242578 2.260547 2.278516 2.279297 2.313867 2.348633 2.348633
8000 1.341602 1.765820 1.913477 1.986719 2.047852 2.097070 2.134180 2.159375 2.172461 2.188867 2.206836 2.224805 2.242578 2.260547 2.278516 2.279297 2.313867 2.348633 2.348633
1999 Camaro M6 LS1 OS 12212156
400 1.080859 1.086133 1.091602 1.091797 1.132031 1.172266 1.212500 1.252734 1.292969 1.364453 1.389453 1.414453 1.439453 1.464453 1.489453 1.532227 1.585547 1.638867 1.638867
800 1.187500 1.192969 1.198242 1.215430 1.255664 1.295898 1.336133 1.376367 1.416602 1.428320 1.453320 1.478320 1.503320 1.528320 1.553320 1.594141 1.647461 1.700781 1.700781
1200 1.116602 1.209766 1.278516 1.337500 1.386328 1.424805 1.453320 1.471484 1.479492 1.475586 1.500977 1.526563 1.552148 1.577539 1.603125 1.659180 1.700586 1.741992 1.741992
1600 1.110547 1.203711 1.358398 1.417773 1.466992 1.506055 1.534961 1.553516 1.561914 1.533398 1.558984 1.584375 1.609961 1.635547 1.661133 1.694141 1.735352 1.776758 1.776758
2000 1.104688 1.197852 1.398633 1.458398 1.508008 1.547461 1.576758 1.595703 1.604688 1.600977 1.626367 1.651953 1.677539 1.702930 1.728516 1.725000 1.766406 1.807813 1.807813
2400 1.013086 1.254297 1.390234 1.468945 1.534180 1.586328 1.625195 1.650977 1.663477 1.668164 1.687891 1.707813 1.727539 1.747461 1.767188 1.778711 1.812109 1.845313 1.845313
2800 1.044336 1.285742 1.439453 1.518164 1.583398 1.635547 1.674414 1.700195 1.712695 1.724609 1.744531 1.764258 1.784180 1.803906 1.823828 1.842969 1.876367 1.909570 1.909570
3200 1.075781 1.316992 1.488672 1.567383 1.632617 1.684766 1.723633 1.749414 1.761914 1.781055 1.800977 1.820703 1.840625 1.860352 1.880273 1.907227 1.940430 1.973828 1.973828
3600 1.330664 1.764648 1.598633 1.673242 1.734961 1.784180 1.820898 1.844922 1.856445 1.874414 1.892383 1.910352 1.928320 1.946289 1.964258 2.019727 2.054297 2.089063 2.089063
4000 1.283203 1.717188 1.674414 1.748828 1.810742 1.859961 1.896484 1.920703 1.932031 1.952930 1.970898 1.988867 2.006836 2.024805 2.042773 2.082422 2.116992 2.151758 2.151758
4400 1.235742 1.669922 1.750000 1.824414 1.886328 1.935547 1.972266 1.996289 2.007813 2.031445 2.049414 2.067383 2.085352 2.103320 2.121289 2.145117 2.179688 2.214453 2.214453
4800 1.188477 1.622461 1.825586 1.900000 1.961914 2.011133 2.047852 2.071875 2.083398 2.110156 2.128125 2.146094 2.164063 2.182031 2.200000 2.207617 2.242383 2.277148 2.277148
5200 1.141016 1.575000 1.901172 1.975781 2.037500 2.086914 2.123438 2.147656 2.158984 2.188672 2.206641 2.224609 2.242578 2.260547 2.278516 2.270313 2.305078 2.339844 2.339844
5600 1.141016 1.575000 1.901172 1.975781 2.037500 2.086914 2.123438 2.147656 2.158984 2.188672 2.206641 2.224609 2.242578 2.260547 2.278516 2.270313 2.305078 2.339844 2.339844
6000 1.141016 1.575000 1.901172 1.975781 2.037500 2.086914 2.123438 2.147656 2.158984 2.188672 2.206641 2.224609 2.242578 2.260547 2.278516 2.270313 2.305078 2.339844 2.339844
6400 1.141016 1.575000 1.901172 1.975781 2.037500 2.086914 2.123438 2.147656 2.158984 2.188672 2.206641 2.224609 2.242578 2.260547 2.278516 2.270313 2.305078 2.339844 2.339844
6800 1.141016 1.575000 1.901172 1.975781 2.037500 2.086914 2.123438 2.147656 2.158984 2.188672 2.206641 2.224609 2.242578 2.260547 2.278516 2.270313 2.305078 2.339844 2.339844
7200 1.141016 1.575000 1.901172 1.975781 2.037500 2.086914 2.123438 2.147656 2.158984 2.188672 2.206641 2.224609 2.242578 2.260547 2.278516 2.270313 2.305078 2.339844 2.339844
7600 1.141016 1.575000 1.901172 1.975781 2.037500 2.086914 2.123438 2.147656 2.158984 2.188672 2.206641 2.224609 2.242578 2.260547 2.278516 2.270313 2.305078 2.339844 2.339844
8000 1.141016 1.575000 1.901172 1.975781 2.037500 2.086914 2.123438 2.147656 2.158984 2.188672 2.206641 2.224609 2.242578 2.260547 2.278516 2.270313 2.305078 2.339844 2.339844
Is it not possible for me to reflash using the 2000 tune with the different OS? Or am I still better off using the 1999 tune with the same OS?
-Shaun
The entire point of using the links Joe posted is to use the NEW 2002 OS and NOT your 99/00 OS. Download the correct tune for your trans (auto/manual), delete VATS, etc then full flash it. Then start tuning it.
And Joe, you're good on the links!
I am sorry I am getting lost. I have a 2000 LS1 Drivetrain and ECU. The ecu was reflashed to a 2002 and it was the 12212156 OS. This was for emissions purposes to help legalize my vehicle. I am not sure what the OS was prior because I did not have EFI Live at that time. What I think was suggested by Joe was to load up the tune that best matches my physical hardware which is a 2000 LS1B M6 and begin tuning from there. This is what I would like to do but on tunefiledepot the 2000 ls1b m6 file uses a different OS system. However there is a 1999 LS1B M6 file that uses the same OS as the 2002. Which is what I think he realized and suggested I use instead. My concern was if there was a difference between the 1999 and 2000 tunes and there was which led to my question in post#18.
-Shaun
Edit: Omg I'm losing my mind confusing people and confusing posts. So, scarab, your suggesting I 1999 migrated LS1B M6 file since it uses the new OS and just removed VATS, EGR, etc? However I did a comparison between 2000 and 1999 and it seems there different hence post#18. Should I be worried about these differences between the 1999 vs 2000 tune, or am I still better off compared to the 2000 vs 2002 tune differences.
-Shaun
