Results 1 to 2 of 2
Thread: AutoVE w/turbos, etc
    Jul 2005
    Default AutoVE w/turbos, etc
    Setup:
    2002 Vette
    twin turbos
    random tech high flow cats
    straight pipes
    Custom OS
    2bar MAP sensor
    AFR sensor lc-1 or lm-1, I forget
    I have a pretty good tune on the car now (thanks to Mike at Xtreme in Tempe), but before the install of the Custom OS should I:
    1. Scan/log AFR and boost pressure.
    2. Use the logged AFR to populate the 105+kPa Boost VE table as a starting point for Boost VE tuning?
    Following the Custom OS install instructions then running AutoVE:
    1. Isn't the MAF disable by the settings from the AutoVE tutorial?
    2. Doesn't the PCM ignore the MAF readings because of the AutoVE settings?
    3. For now, can't I use the IAT in the MAF and leave the MAF in place and plugged in so I am using he IAT sensor in the MAF?
    4. What advantages are there to removing the MAF other than easier breathing?
    Lots of questions and I appreciate the help.
    Lonnie in Colorado Springs
    2002 EB Coupe, MN6
    Xtreme TTi Twins @8psi, Dual A-pilar gauges - fuel&boost, x-pipe, Borla Straight Twin Oval from Cats on back, Hurst Short Throw, CCW 3 piece rims - 18x9.5/275-35 and 18x11.5/335-30 Pilot Sports
    Drive it like you stole it!!!!!
    I'll be watching as this will be my next mod with efi.
  1. Replies: 32
    Last Post: June 24th, 2010, 06:21 AM
  2. doing autoVE
    By nathans1987 in forum Gen III V8 Specific
    Last Post: May 3rd, 2009, 06:20 PM
  3. AutoVE with V2?
    By nonnieselman in forum Custom Operating Systems
    Last Post: March 24th, 2008, 07:50 PM
  4. Custom OS w/Twin Turbos B5956
    By lplott in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 8th, 2006, 02:50 AM
  5. AFRs and Turbos
    By oztracktuning in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 27th, 2006, 03:44 PM
