Results 1 to 2 of 2
Thread: 16263425 OS 4L60e to 4L80e swap?
    Jun 2008
    Default 16263425 OS 4L60e to 4L80e swap?
    What all do I need to do to swap a 4L80e into my 98 Z71, electronics wise? Do I just need a harness/or repin the current one and do a 4L80e segment swap like you do on the LSx?
    If so, anyone got a 16263425 OS 4L80e tune?
    -John
    1991 RCSB 2WD Sierra LQ4 swap, 220/224 112 cam, Twin VSR 6766 turbos
    4L80e w/shift kit, PY 3600, and 3.73 gears.
    22 PSI and E85, 4300# with driver. 9.7@138, 1.47 sixty
    :drivin:
    Aug 2006
    PM me your e-mail address and I will send you the wiring instructions----There's not much to it. I am not sure if I have a 98 4L80 calibration or not. I will check tonight when I get home from work.
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
  1. TBSS 4L60e to 4L80e T42 Swap
    By Mike@Vengeance in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 4th, 2013, 07:34 PM
  2. 4L80E swap into 2006 6.0L truck with 4L60E
    By powermonger in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2010, 03:59 AM
  3. Using a 4L80E in a 4L60E car..
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 12th, 2009, 05:03 PM
  4. 4L60E to 4L80E swap
    By hquick in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 22nd, 2007, 08:48 PM
  5. 4l60e ---> 4l80e What changes ?
    By Tydriver in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 2nd, 2006, 02:40 PM
