Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 76
Thread: EFILive Pre-Release 06
    Just found another bug, Ive never used it before but using the Edit in V7 button in the V8 tune->Edit gives the attached error.
Name:	V7 open error.PNG
    May 2010
    I want to know if the 2013 GMC trucks are supported now ?
    EFILive Tuner
    Lifetime Member Rhino79's Avatar
    Jul 2006
    WOW, the new dashpage layout and pids are sweet for the e38 and t43, looks like we have a lot more pids now??
    Head Calibrator
    Gwatney Performance Innovation
    Jacksonville, AR 501-982-2102
    Jul 2007
    Was there a FS / AC firmware change for RC6?
    I seem to have lost the ability to set alarms in the V2. Even though the setup indicates the LED's should be in alarm mode, they are stuck in status mode (I get one orange LED flashing all the time indicating vehicle comms).
    Jul 2006
    I think so, Should be dated Feb xx instead of January
    Head Calibrator
    Yes there was but it should not have affected the LEDs. I'll look into it.
    Dumb question I know, but I presume you have V7 installed?
    V8 used the V7 executable path as defined by this registry key:
    \\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Cu rrentVersion\App Paths\EFILive_Tune.exe
    If that key does not exist or is wrong then V8 can't start or run the V7 software.
    Can you check that registry key on your system please?
    Ignore all that, it was a permissions problem. The V8 software was attempting to open the key for read/write (and users don't have write permission to that key).
    I changed it to open with only read access and it fixes the problem.
  9. #19
    Ah I see, thanks for checking it out!
    Yes I have V7.5 installed, I do have that reg key fwiw. Full local admin privileges on this machine as well.
  10. #20
    Jan 2013
    The LEDs are working for me in the alarm mode. As soon as I switch it back to "status" using the arrow keys on the V2 it starts flashing the vehicle comm light.
  1. EFILive Pre-Release 05
    Last Post: July 16th, 2013, 12:20 PM
