Page 8 of 8 FirstFirst ... 678
Results 71 to 76 of 76
Thread: EFILive Pre-Release 06
  1. #71
    Aug 2012
    If you want to go back to the version dated June 22, 2012, use the EFILive Explorer program (available on the EFILive V8 start menu) and you can load the firmware file of your choice, so long as the version number is not earlier than what is already in your device.
    Paul i Loaded June 22 2012 into the handheld. it will open V7 but it doesnt recognize the handheld is plugged in. when I put the laptop and handheld in my truck and check the status i get all 3 check marks. but when i load V7 it hangs up unless i unplug the handheld. and if i plug the handheld back in and try to flash my truck it freezes.
  2. #72
    Quote Originally Posted by FreshDA9 View Post
    Odd as i went through and edited my post apperently it did not edit.
    You might see something like this if you go back in your web-browser.
  3. #73
    Did you revert the USB driver to the old one (see post #65 above)...?
  4. #74
    Aug 2012
    Yes
  5. #75
    Have you tried 1) different USB ports and 2) a different PC? If you're having this many issues, it might be a PC problem either software or hardware.
    Try installing everything on a different PC and see if you can open V7.5 that way. Ive had no issues on any of my PCs [2 laptops (HP, Lenovo), 4 desktops (all custom built by me using different mobos and USB chipsets), Windows 7 x64 or Windows 8 x64].
    Wait, are you trying to open V7.5 after you've already opened V8? You CANNOT have both V7.5 and V8 connect to your V2 at the same time, V8 will automatically override V7.5. Close V8, then try to open V7.5.
  6. #76
    Aug 2012
    I havent tried another computer i can try my other laptop but I still think its something within the handheld.
    I have already cleared out all the software and deleted all files associated. then followed up by cleaning out my ports by using FTDI.
    No i do not have them both open. this is just an issue with V7 and the FSV2 handheld since this pre release 6, 5 worked fine.
  1. EFILive Pre-Release 05
    Last Post: July 16th, 2013, 12:20 PM
