Ok I have been dealing with this E38 ecu way to long. I am understanding the zones and the fact that if you edit part f a zone you need to edit the full zone. Im still getting use to the generate Coef and VVE.
Problem is the tutorials say to Copy with labels my data log and then paste with labels multiple well every time I do the map just flattens out.
Here is a long log i did on the dyno trying to just fill cells.
Log_0025.efi
Here is before i apply the paste function
And here is what happens when i paste.
I have tried selecting my external wideband. I have tried pasting the BEN also. either one always ends with a flat map. I have tried all the paste options including multiply divide add subtract etc.
I have been tuning in open loop on the 2 bar table as indicated in the Virtual VE tutorial and also added more fuel to the areas for boost etc as said in the PDF. can someone help me. I have been manually tuning every cell and it takes tons of time even with interpolation.
Sorry Im just exhausted with this car and at a breaking point
