Results 1 to 5 of 5
Thread: SKIM key codes
    Dec 2012
    Default SKIM key codes
    I recently switched from my 06 OS to a 07 OS off tune depot in order to try and minimize throttle hang. I downloaded the new file, changed the vin, saved it, then flashed it into the truck. The first startup the truck ran then stalled with a CEL, I tried to start it a second time and all went well and it continued to run but now I have a P0633 & P0513 that will not clear. The CEL is not on now and the truck runs great, is this common with switching OS's?
    Thanks for the help
    2005 Cummins - EFILive Conversion - S474 single - 1325hp on the spray.
    Did you make sure that you reprogrammed the VIN in the new tune? If not, I think your only option is a dealer reflash...but Ill let someone who deals with these engines more frequently than me answer definitely.
    Nov 2010
    When I flash a OS that's not what mine came with, I get a SKIM error, but it's a soft-code.
    I wouldn't worry about it.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Senior Member DODGE74's Avatar
    Oct 2011
    Les, couldn't he turn off the code in the DTC tab to get rid of the code?
    06 QCLB, DRW
    Single pump
    Single turbo
    EFILive 772hp 1398tq
    gordon@innovativediesel.com
    Nov 2010
    Possibly...I've never tried.
    Les Szmidt
    2007 5.9 Dodge Ram
  1. 06-07 cummins engine conversions (skim)
    By crtune in forum Cummins 5.9L
    Last Post: January 23rd, 2012, 05:31 PM
  2. P0633 skim key
    By BSwope in forum Cummins 5.9L
    Last Post: October 24th, 2011, 10:25 AM
  3. key code
    By beaukz28 in forum Purchase and Shipping
    Last Post: October 14th, 2008, 04:35 PM
  4. Registration Key
    By way2much_01 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 8th, 2008, 08:38 AM
