Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Surging on cruise/ light throttle
  1. #21
    Feb 2011
    Quote Originally Posted by CIDRAUGHN View Post
    Thanks for the reply. I have been over every spot in the pulse map to try and find an abnormal jump, even tried raising the pulse in those areas to make it stay in that pulse pressure and mpa instead of jumping to the next column. Of course I smoothed out each time. Come to think of it, this is also an 07 manual. Do you think that by chance it may be an OS issue?
    You said you tried raising pulse, that'll make it worse.
    It needs to be reduced until.it's happy, it's a commanded fuel problem...too much too quick
    If you don't mind sending me the tune, I can do some adjustments to try..
  2. #22
    Jan 2010
    Bringing this back up, I have an 06 that does the exact same thing. Did you ever figure out the problem? Thanks
  3. #23
    May 2009
    I haven't seen the truck I was having issues with for awhile so no progress here, however I must eat some crow on my modded FCA comment above! I have installed an arson III kit from Shane at Motorsport Diesel in a new pump and installed it on my truck and WOW! It performs above expectation and flawlessly! Ok sorry for the derail.
  4. #24
    Feb 2020
    I
  1. TCC slips at light throttle
    By rumblebox in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 5th, 2012, 05:13 AM
  2. light throttle surge.
    By activity233 in forum Gen III V8 Specific
    Last Post: November 25th, 2012, 12:14 PM
  3. Cruise Control Surging
    By ViciousKnid in forum Gen III V8 Specific
    Last Post: February 9th, 2010, 05:55 AM
  4. Tuning out surging on and off throttle
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: July 11th, 2009, 06:07 PM
  5. For those who are having Idle and Part-Throttle Surging
    By RacerChris in forum Gen III V8 Specific
    Last Post: November 20th, 2008, 03:17 PM
