Results 1 to 8 of 8
Thread: E39 Camaro v6 as a swap transplant?
    Nov 2006
    Default E39 Camaro v6 as a swap transplant?
    Is this pcm/ecu as manageable as a swap candidate? Will it work without all the other interfaces from the Camaro? Tune-able? Searched and it seems to be but... Hate to buy it and find I can't make it work.
    Yes, I know of some E39's that are being used as transplants, we have a VATS patch available for it.
    Nov 2006
    Awesome! Thanks for the quick reply, as always.
    Nov 2006
    Bringing this back so I can be really clear, the V6 Camaro 2010-11, is or is not supported? I don't see it under supported vehicles although I do see a few other 3.6L cars.
    Thanks in advance
    Not supported, E69 or E69-4 ECM. You can scan/log, read/flash, but no calibration mapping is available from EFILive. I.e. tuners use 3rd party tools to develop their tunes/calibrations then use EFILive to read/flash.
    Nov 2006
    Ouch! Anyone know anything about the differences between the e69/e39 camaro's? Can I swap out the harness/ecu to a 12+, sensor differences? Crankshaft tooth count?
    Dec 2007
    I'm gonna beat a dead horse. Could I remove the theft on a e69 ECM for transplant. I understand it's not supported for tuning, but if I just wanted to remove the theft so I can start the car, is that possible?
    EFILive doesn't know how to disable theft on that ECM, if you find someone that does the best we could offer is you could flash the tune in.
  1. G8-Camaro cal swap
    By Webbs in forum E37, E38 & E67 PFI ECM's
    Last Post: April 10th, 2012, 07:11 AM
  2. 6.7L Cummins swap/transplant
    By wilintolern in forum Cummins 6.7L
    Last Post: November 28th, 2011, 03:40 PM
  3. 03 Z06 swap into 71 Camaro...
    By 2007 5.9 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 26th, 2011, 01:51 AM
  4. ls7 swap to 2010 camaro
    By dgdyno in forum E37, E38 & E67 PFI ECM's
    Last Post: April 24th, 2011, 03:27 PM
  5. 98 camaro engine swap
    By pdasterly in forum Gen III V8 Specific
    Last Post: May 27th, 2009, 03:07 PM
