Results 1 to 3 of 3
Thread: compatibility question
    Apr 2009
    Default compatibility question
    can u do scanning well data logging on a 2003 saturn L300 with a 3.0?? i seen in the list it will do a 2.2L but what about a 3.0?
    2006 Chevy Ext Cab SB 2500 LBZ 4x4 EFI LIVE w/ Turbo brake
    5" stacks egr blocked no kitty 285/70/17 nitto terra grapplers fass pump custom air intake tru trac diff in rear water/meth inj. race fuel valve
    2001 Chevy Std cab 12' ultility bed with pipe rack 3500 2wd LB7 with 6 spd manual custom exhaust system and ppe boost increase valve
    Duramax ROCKS
    Scanning should be fine, just select it as a VPW controller (such as an LS1 etc), v7.5 will then validate whatever PID's it supports and you should be set to go. (I'm assuming it's a VPW ECM), I also had no idea they had a 3.0L, that wasn't one of GM's engines was it? I'd heard of the 3.5L.
    Apr 2009
    im not sure if its a Gm engine or not i just know it offered a 2.2 4cyl and 3.0 6cyl if memory serves me right ... the L200 had the 2.2 and the L300 had the 3.0.. i think reason I'm asking I'm out of state right now and working on this car and trying to figure out if its worth have my efilive sent here or just pay 100.00 at a shop to do it
    Duramax ROCKS
  1. Windows 8 Compatibility
    By robertleeii in forum General
    Last Post: June 18th, 2012, 03:17 PM
  2. 69 camaro e38 ecm compatibility question
    By EVI in forum E37, E38 & E67 PFI ECM's
    Last Post: April 11th, 2012, 11:23 AM
  3. Replies: 8
    Last Post: August 13th, 2010, 04:54 PM
  4. Compatibility
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: December 18th, 2008, 12:53 PM
  5. PLX wideband compatibility question
    By robz in forum General
    Last Post: August 4th, 2008, 10:54 AM
