Results 1 to 8 of 8
Thread: Timestamp and Mileage Readings
    Apr 2009
    Default Timestamp and Mileage Readings
    I'm trying to use the scan tool to take OBDII data on a project for the day job and I can't seem to get the tool to give me a single screen that shows the current timestamp, mileage, DTC status (even if none exist!), readiness indicators, and monitor status (passed/not run). I see that we can get a report showing current/pending DTCs and readiness status, but it has no timestamp or mileage. I also see that we can log miles since codes cleared in the PIDs, but again this is not timestamped, doesn't show actual odometer reading, and isn't tied to a DTC display either. Am I missing something? CARB requires that these be shown in a single file/picture for certification and I was hoping EFIlive would work.
    ~Greg
    Calibrated Success - EFI Training and Tuning Done Right
    GM Beginner's Guide DVD available now through Summit!
    Engine Management: Advanced Tuning - Amazon's best deal for the EFI crowd.
    May 2010
    For real? Your kidding right?
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    Hmmm, is CARB interesting in seeing Mode $6 data for any reason...?
    What is the difference between readiness indicator and monitor status...?
    Using FlashScan in standalone mode you can generate a fairly comprehensive list of OBDII/CARB/EPA data.
    Use F3->F4, then use EFILive_Explorer to copy the generated file to your PC.
    Its not exactly what you want, but its a start.
    While the V8 scan tool is being developed that report will be enhanced with additional data and the items you suggested will most likely make it into the report.
    Here's a sample of what the report looks like:
    Code:
    [PCM INFO]
    VIN=6G1ZK54F05L000000
    OS=12592433
    Stream=LS1B
    [PCM CVN]
    ; No CVNs detected.
    [System Readiness Tests]
    MIL=OFF
    DTC_CNT=0
    MIS=N/A
    FUEL=Ready
    CCM=Ready
    CAT=N/A
    HCAT=N/A
    EVAP=N/A
    AIR=N/A
    ACRF=N/A
    O2S=Ready
    HTR=Pending
    EGR=N/A
    [DTCs EPA Current]
    ; No DTCs detected.
    [DTCs EPA Pending]
    ; No DTCs detected.
    [DTCs Enhanced]
    ; No DTCs detected.
    [MODE05]
    ; Mode $05 data could not be retrieved.
    [MODE06]
    ;ID    MinLimit    Value MaxLimit Units    Result
    0204.L=       0,       0,       -,        ,OK    ,"EVAP Canister Loading Test"
    0266.H=       -,     0.0,     0.0,inH2Ov  ,OK    ,"EVAP Excess Vacuum Test 1"
    0236.H=       -,     0.0,     0.0,s       ,OK    ,"EVAP Excess Vacuum Fail Test 2"
    0206.L=     0.0,     0.0,       -,int-s   ,OK    ,"EVAP Excess Vacuum Pass Test 2"
    0250.L=     0.0,     0.0,       -,inH2Ov  ,OK    ,"EVAP Weak Vacuum Pass Test 1"
    0260.H=       -,     0.0,     0.0,int-s   ,OK    ,"EVAP Weak Vacuum Fail Test 1"
    0230.L=     0.0,     0.0,       -,s       ,OK    ,"EVAP Weak Vacuum Test 2 Vacuum"
    0240.L=     0.0,     0.0,       -,s       ,OK    ,"EVAP Weak Vacuum Test 2 Vapor"
    0252.H=       -,   0.000,   0.000,inH2O/s ,OK    ,"EVAP Small Leak Vacuum Decay Rate Test"
    0211.L=     0.0,     0.0,       -,s       ,OK    ,"EVAP Purge Leak Pass Test"
    0221.H=       -,       0,       0,s       ,OK    ,"EVAP Purge Leak Vapor Fail Test"
    0271.H=       -,     0.0,     0.0,inH2Ov  ,OK    ,"EVAP Purge Leak Vacuum Fail Test"
    0501.H=       -, 389.969,2047.969,mV      ,OK    ,"Rich to Lean Sensor Threshold Voltage - B1S1"
    0502.H=       -, 389.969,2047.969,mV      ,OK    ,"Lean to Rich Sensor Threshold Voltage - B1S1"
    0503.H=       -, 250.000,2047.969,mV      ,OK    ,"Low Sensor Voltage for Switch Time Calculation - B1S1"
    0504.H=       -, 624.969,2047.969,mV      ,OK    ,"High Sensor Voltage for Switch Time Calculation - B1S1"
    0505.H=       -,   0.000,   0.000,ms      ,OK    ,"Rich to Lean Sensor Switch Time - B1S1"
    0506.H=       -,   0.000,   0.000,ms      ,OK    ,"Lean to Rich Sensor Switch Time - B1S1"
    050A.H=       -,       0,       0,Samples ,OK    ,"Post Catalyst Sensor Open Test - B1S2"
    050C.H=       -,   0.000,   0.000,mV      ,OK    ,"Post Catalyst Sensor Lean Tests - B1S2"
    050D.H=       -,  -32768,  -32768,ms      ,OK    ,"Difference Between R/L Response and L/R Response - B1S1"
    0541.H=       -, 389.969,2047.969,mV      ,OK    ,"Rich to Lean Sensor Threshold Voltage - B2S1"
    0542.H=       -, 389.969,2047.969,mV      ,OK    ,"Lean to Rich Sensor Threshold Voltage - B2S1"
    0543.H=       -, 250.000,2047.969,mV      ,OK    ,"Low Sensor Voltage for Switch Time Calculation - B2S1"
    0544.H=       -, 624.969,2047.969,mV      ,OK    ,"High Sensor Voltage for Switch Time Calculation - B2S1"
    0545.H=       -,   0.000,   0.000,ms      ,OK    ,"Rich to Lean Sensor Switch Time - B2S1"
    0546.H=       -,   0.000,   0.000,ms      ,OK    ,"Lean to Rich Sensor Switch Time - B2S1"
    054A.H=       -,       0,       0,Samples ,OK    ,"Post Catalyst Sensor Open Test - B2S2"
    054C.H=       -,   0.000,   0.000,mV      ,OK    ,"Post Catalyst Sensor Lean Tests - B2S2"
    054D.H=       -,  -32768,  -32768,ms      ,OK    ,"Difference Between R/L Response and L/R Response - B2S1"
    0507.L=       0,       0,       -,Switches,OK    ,"Rich to Lean Switches - B1S1"
    0508.L=       0,       0,       -,Switches,OK    ,"Lean to Rich Switches - B1S1"
    050B.L=   0.000,   0.000,       -,mV      ,OK    ,"Post Catalyst Sensor Rich Tests - B1S2"
    050D.L=  -32768,  -32768,       -,ms      ,OK    ,"Difference Between R/L Response and L/R Response - B1S1"
    0547.L=       0,       0,       -,Switches,OK    ,"Rich to Lean Switches - B2S1"
    0548.L=       0,       0,       -,Switches,OK    ,"Lean to Rich Switches - B2S1"
    054B.L=   0.000,   0.000,       -,mV      ,OK    ,"Post Catalyst Sensor Rich Tests - B2S2"
    054D.L=  -32768,  -32768,       -,ms      ,OK    ,"Difference Between R/L Response and L/R Response - B2S1"
    0C60.H=       -,   0.000,   0.000,s       ,OK    ,"Catalyst Test Bank 1 (Using OSC Compensation Units)"
    0C70.H=       -,   0.000,   0.000,s       ,OK    ,"Catalyst Test Bank 2 (Using OSC Compensation Units)"
    0E11.H=       -,       0,       0,Samples ,OK    ,"Oxygen Sensor Heater X/Y Samples Test - B1S1"
    0E21.H=       -,       0,       0,Samples ,OK    ,"Oxygen Sensor Heater X/Y Samples Test - B2S1"
    Apr 2009
    Its not exactly what you want, but its a start...
    That's pretty much what I was already able to generate in V7.x It's the complete report, minus the critical timestamp and mileage at reading. CARB will NOT accept our report without these, so it's still a deal breaker at the moment. I really appreciate that you're looking into this. Adding this functionality will be a big help in the future for a lot of people who don't even know they'll need it yet. Please keep adding great stuff like this to what is already an excellent tool set. In the meantime, it looks like I need to find a "plan B".
    ~Greg
    Hi Greg, what are you doing with/for CARB, if I may...?
    The odometer reading is not something that can be obtained using generic OBDII PIDs. I can't imagine that CARB would require a scan tool obtain data that is not defined by the J1979 specification.
    Are you 100% sure that the odometer reading must be part of the report, if so then it will most likely need to be obtained visually from the odometer by the technician doing the inspection and written on the report manually.
    The time stamp and odometer readings from the following generic PIDs can also be easily added in an EFILive update:
    MIL_DIST
    CLR_DIST
    May 2010
    Quote Originally Posted by eficalibrator View Post
    Its not a 5,000 dollar tool either.
  1. Help with a mileage tune
    By johnj in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 17th, 2011, 01:34 AM
  2. lb7 fuel mileage
    By erisk71 in forum Duramax LB7
    Last Post: April 12th, 2011, 04:16 PM
  3. poor mileage :(
    By Boost in forum Gen III V8 Specific
    Last Post: July 12th, 2010, 02:17 PM
  4. Is the timestamp in the data files
    By McRat in forum External A/D inputs
    Last Post: October 26th, 2008, 12:57 AM
  5. 02 5.3 Suburban Mileage tune.
    By SS Duramax in forum Gen III V8 Specific
    Last Post: June 22nd, 2008, 07:42 PM
