Is there a way of converting LS1 edit file to efi live. My tuner has upgraded my file in ls1edit. Please advise.
2002 GMC Sierra ECSB
Turbonetics T7675 6lbs boost, 42lb injectors, Single 4 inch exhaust with Hi-Flow Cats, 6.0 swap, Comp Cam LS9 Cam, EFIlive Tune, E-fans, Snow Performance Meth Kit, soon to add KB Boost a Pump,
EFILive can't open a LS1Edit file directly. What is possible is to use EFILive to read the LS1Edit data from the PCM (if it isn't locked). From that point forward, one can use EFILive for tuning.
2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
Flashing control modules since 2001. 8-)
Who needs a MAP sensor on a supercharged LS6 anyway.
Can anyone help me with the conversion. I can send the file out in LS1 format. I desparately need this for my 4l80swap.
SOS
Why can't you do what SinisterSS suggested, download your current tune from your PCM? (I.e., use the PCM as the converter.) The file format itself is proprietary.
